2009 toyota corolla engine noise
i have started this car after 30 days. initally there was no noise then i'm getting this noise.
engine oil and water level is ok.
By
owaishanif786, September 3, 2017
Have you been able to drive the car, and are you getting a check engine light. Did you have any luck finding the issue?
Sounds like a diesel engine.
This may be issue:
"The ticking is due to sticky valvetrain components". Please see this interesting post:
https://community.cartalk.com/t/2003-corolla-oil-light-comes-on/76474/2
I think you have same problem as this person:
They replaced piston rod bearings. You will need to remove oil pan.
