Hi,
Can anyone tell me what the length of the cables are on the 01 Corolla CE? I cant for the life of me find the measurements. I am going to replace it with 4/0 gauge wire with copper lug terminals. Do I need to do anything additional to the positive cable since the original travels through the engine wiring harness behind the intake manifold?
I just recently replaced my terminal ends because of a no start situation and it fixed it, but I cut away about 6 inches of insulation on each cable and there was greenish-blue corrosion the whole way down the center. I taped it back up and installed the new terminals. So I am just going to replace all three cables (i'm not sure where the third is?) and call it a day. Starter has started to drag a little starting the car afterwards and I had the battery and alt tested on and off the car at several stores just to be sure they were actually good. I'm sure a starter and/or solenoid rebuild is in the future, but I'm just going to press forward under the assumption it's the cables.
