16" Steel Wheels On 2011 Sienna
Hi,
I was wondering if anyone has ever downsized or minus sized to 16" steelies on a 2011 and up Sienna. Oem is 17".
By doing so, opens up allot more options for tires- winters to be more specific.
Will 16" steel wheels fit around the brake calipers?
Winter is approaching fast and soon here in Canada and 17" tire options are limited and quite expensive.
Can't find much below $180 apiece.
Any comments will be appreciated.
Tks
The 16" wheel setup will mount without problems and you'll find that many siennas come with 215/65R16 tires.
Yes, the lower trim levels come with smaller wheels so they should all interchange except maybe the SE. There are a lot of good used-wheel sellers out there.
Just avoid the cheep Chinese import wheels, they're usually not good for very long... though now it's confused because there are also good Chinese wheels...
test
