Hi,
In advance, thank you for your replies. I appreciate all the help I can get!
I have a 2002 Chevrolet Prizm (corolla essentially, as I'm sure you know) and it has some wheel bearing issues. I received a quote from a local shop that was much too high, so my father in law and I are going to tackle it ourselves.
I have a couple of questions.
1.) The shop said the wheel bearing was prepacked so it couldn't be rebuilt, which makes sense. DOes this mean that all i have to do (assuming the hub is OK) is press out the old bearing and press in the new? Or do I have to replace the hub assembly?
2.) Both bearings (front) are bad. Is there some other components that I need to check to make sure there isn't something upstream that is causing abnormal wear?
3.) Will I need a slide hammer to remove the hub assembly or is it relatively easy on these cars? Most of what I see and read is that people are not needing them but I'm still not quite sure.
Thank you for your responses, I appreciate the help.
