My front end was making noise, didn't feel right, and just felt loose. I went to 2 chain places to get it diagnosed and one local shop. I"ll be doing the work myself along with my DIY best friend Manual Haynes. See what I did there? Hahahahaha. The consensus is this, I need to do front and back end suspension/steering work, (btw my 2000 CE has only 78,500 miles, all these repairs seem untimely too much, I don't drive nuts, is this normal? Previous owner? the 16" aftermarket rims are responsible?):
0) Rear Hub Assemblies (I've done this b4 once, (and the front also), so no biggie easy)
1) Lower Control Arms (Both)
2) Inner Tie Rod (Just Left) - Should I do the right one as well?
NOW, the following I'm uncertain about whether these parts are all together, separate, and the order of operation, as to not repeatedly have to remove the same bolts/nuts 2 or 3 times:
3) Sway Bar Links (Kit?) - Front and Rear
4) Link Pins - All: Front and Rear, Left and Right
5) Front Lower Control Arm Bushings - Rear (this is how it is written on my estimate, as strange as this looks)
6) Stabilizer Bars?
7) Ball Joints?
ALSO: is there anything else I should INSPECT/REPLACE while I'm working on the above? are there any MODS/PERFORMANCE UPGRADES I should/could do while I'm doing this?
Please state what the order of operation should be.
THANK YOU VERY VERY MUCH Toyotaville!
btw: http://www.haynes.com/ <<< complete manuals are a life/time saver y'all!
