Wow - 4 months on 3-cylinders. Pretty tough engine.
I don't know about a timing belt would hold up on most 7th gens for 200K miles. Many a few here or there, but that is not typical. Waterpumps generally would go before that and the timing belt tensioners will not last that long (ask owners that didn't replace the tensioner when they replaced the belt - majority of them probably shredded the second belt). The timing belt on my 3rd gen Camry got changed out every 60K miles - looked like new. Pushed it to 120K miles, now it starts to look a little rough. To push it 200K miles, even with mostly highway cruising - would be very sketchy.
That said - I do agree that the older cars were built better - that 3rd gen Camry with the 2.2L 5S-FE - bulletproof. Got 385K miles and still rolling - consumes less than 4 oz of oil every 5K miles oil change, body has almost no rust - even living in the saltbelt (Ohio), original engine and transaxle, all major replacement parts were OEM, everything else aftermarket.
I do agree that the A-series engine is well respected and known to be near bullet proof. But you also have to think that they had lots of time as well, close to twenty years of refinement and design, for the 4A series. The A-series in generally were developed as a K-series replacement in the 70's. The 1ZZ-FE had a complete paradigm shift in design - had to light, compact, fuel efficient, and more powerful. Aside from potential for stuck oil rings and EVAP related issues - the 1ZZ-FE is actually pretty solid for a new design. The 9th gen fixed the oil and EVAP issues, but I personally fell backwards with the DBW implementation. Could have been better, especially with the ones they already had on the Lexus product line.
