I may get ambitious enough to remove the oil pan from a 4AFE engne that is in a friends '90 Corolla. I'll be able to see the inside of the engine while lying under the car. What problems can I detect from that position?
The engine which has about 200,000 miles on it. We don't think it has a problem with rods, crankshaft or bearings. However, it would be nice to know how to make a routine check. I understand how to check if a rod is actually loose on the crankshaft, but how would I detect a less obvious problem like a "spun" bearing? Would I have to start removing bearing caps?
The engine may have worn rings. I suppose there's no way to check that from underneath the pistons.
