- 7 posts
I changed a front bearing of my Corolla 2000 at a shop last year, but it is failing now. The same shop confirmed that it is the same bearing.
Can someone suggest why? I read that tightening the axle nut too much can lead to premature bearing failures (the mechanic at this shop told me that he uses impact gun and not torque wrench for the axle nuts), the same mechanic thinks that if the knuckle is damaged, say having a crack, then that can do that too. I also wonder if a low quality bearing was used.
I am leaning toward doing the next bearing change myself so that I can have more control of the parts and torques. It would be nice if I can buy the entire knuckle-bear-hub assembly so that I can avoid the difficult steps of pressing, but I haven't found any such new item on sale so far. Should I consider getting a used entire assembly from a junk yard?
Thanks.
