Guest devo
Hello all
I just pulled codes 31 and 41 have no clue on how to correct them can some one please help?
1989 corolla wagon FWD 4 AF engine with 2br carb
31 Air Flow Meter signal (Vacuum Sensor signal).
41 Throttle Position Sensor signal.
By
Guest devo, September 27, 2010 in Pre-1997 Toyota Corolla and Geo Prizm
Hello all
Need a bit more information. How is the car running - running poorly, running OK, not running at all? Did these codes just pop up or were there for a while? What is the history of the vehicle - past maintenance?
Code 31 - Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed, affected systems are the airflow meter circuit or a bad ECM
Code 41 - Open or short circuit in throttle position sensor signal (VTA), affected systems are the throttle position circuit or a bad ECM
You'll need to get your hands on a wiring guide, need to have some basic tools and a good multimeter. Just a note, could be a bad sensor, or an issue with wiring. Sensor replacement if pretty straightforward, but wiring troubleshooting can be a nightmare.
Good example, a reference site to give you an idea on what to check (note this is for a Toyota 4Runner, so values could be different, sensor locations, and relevant wiring - but the diagnostic "procedure" would be the same)
TPS issue - http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
AFM issue - http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
