I have a 1999 AE110 Corolla with a 5A-FE engine. The engine starts good when cold and runs well. However when its hot, and I switch off for 15 mins, it would hard-start after and then run normally? I was suspecting that I have a dribbling injector, how how can I check for this? Also, I tested the Engine Temperature sensor with an Ohmeter and the readings were within specification. What else could be the culprit for this problem? I also get an idling problem at times when the engine is hot, the rpm drops but the car idles as if it wants to cut off but it doesn't cut off. I cleaned the idle air control valve and throttle body and the problem persists, I also tested the resistance of the IACV and its good. Any gurus on the forum, please provide some assistance! Thanks!
