Thanks for the info, fish.. but unfortunately the problem has just deteriorated. I connected a pressure gauge to the low end, but did this while it was cycling so I couldn't get a good read. According to my ambient temp and the instructions with the pressure gauge, the pressure should be about 50psi (assuming the clutch is engaged).
Now, driving the car today, the clutch will engage/disengage constantly, starting from inside a minute after turning on the A/C. So it's doing it without sitting idle.
First question; What should the pressure be while the clutch is NOT engaged?... Asking this because I get more time while not engaged, only a second or maybe two while engaged, so I'm not sure if I'm getting an accurate read while engaged.
Second question; What are the possible reasons for the clutch cycling constantly, now without sitting idle heating it up.
Third question; Could I possibly have a bad clutch? ... Hoping so since that seems like an easier and cheaper fix that I could do myself.
The only fan that I know about is the radiator fan on the driver side. Can you direct me to the condenser and fan? I don't remember seeing them.
EDIT: I should also note that turning on the A/C while driving has a noticeable performance effect on the engine when the clutch engages. Not significant, but noticeable.
DOUBLE EDIT: I checked the condenser and fan. Condenser has some wear, but it's been through 250K miles. Fans work too (both radiator and condenser fans).
Thanks for the help.
