Guest billwagnon
My son's 97 failed emissions and has some other problems at 260,000 miles.
So I bought a 93 Corolla today with 160,000 miles. The airbag light on the 1993 is on. Is it possible to swap the airbag from a 1997 to a 1993?
thanks!
By
Guest billwagnon, March 21, 2010 in Pre-1997 Toyota Corolla and Geo Prizm
thanks!
As those are the same generation - they are likely to swap over with little issue. The problem is the airbag lamp - it is unlikely to be a problem with the airbag itself, usually a problem with the wiring for the SRS system. You'll need to pull the code stored in the ECM and go from there.
