from another board on misfires and multiple codes ,but a good primer on diagnosis.
Originally Posted by chubbygoatboy
99 Corolla -- To make a long story short as possible, the car had 5 stored codes. Two Cyl. 1 misfires, Two cylinder 4 misfires, and one random, multiple misfires. I then cleared the codes.
I replaced spark plugs, and wires. Drove it, and immediately it was still missing. Codes now read cyl 1 and cyl 4 misfires, one each.
So, now it looks like maybe coil pack, since both 1 & 4 are on the same pack. So, I bought new coil pack and replaced it. Still runs like crap, and now I get only cyl 4 misfire. So I swapped plugs and wires around just in case one of the new ones was bad, still cyl 4 misfire, P0304 code.
I checked compression, and got 210, 210, 190, 190, so I think that looks OK.
The #4 plug is damp, and clearly not burning. HELP, and Ideas are greatly appreciated!!
Now, I switched coils to rule out the new coil being bad. It still has the same misfire code. So it appears that the plugs, wires, and coils are OK. WHATS LEFT?? Could the fuel injector do this??? Any thoughts are appreciated!!
Well, I have answered my own questions. So I will post what I found in hopes that it might help someone else!! I swapped the #4 injector, with #3, and guess what, the misfire moved to #3 cyl. So a new injector is on order.
and another:
I found on line that the p300 coad is a random missfire in all cylinders and that the last number in a p300 code is the cylinder that is misfiring. Your p302 & p303 would be #2&3 cylinders.
Answer
injectors are often the cause of misfire codes on this year and model.
Answer
The first thing to try would be new spark plugs plugs and plug wires. This fixes misfires the majority of the time. If that doesn't help check the rotor and fuel injectors.
Answer
Either a bad coil or bad fuel injectors. try switching coils with other cylinder and see if code changes. if yes, you got a bad coil, if not, you must change all 4 injectors, cause they will all go bad eventually. I've seen it. I was a Toyota technician.
your vehicle does not have plug wires ,but you probably have a bad injector. I would clear codes and buy a code checker.
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=94168
i hope this helps.
