Guest rustyjones
The 1st gear does not work when taking off from a stop if in drive, but it works when manually shifted into 1st, it also works fine when throttle is pressed to shift into passing gear, any suggestions would be greatly appriciated.
Check the fluid.
Check the fluid.
fluid is good just a little overfull when it is cool
fluid was checked with the engine running?
3 speed or 4 speed?
Maybe you have worn out your clutch plate?
