Well, thanks to all for the advice on fixing the rear brakes. 1stToyotaParts was also a big help.
The only item on my list that I haven't fixed was the rear shocks. I was going to order some OEM shocks, but then thought about what newer technology shocks might do for my car. I use my car for ferrying around both people and things, and I'd like to make the ride smoother for rear seat passengers. Most of the roads where I live are quite potholed, criss-crossed by railroad tracks, and dips. The highways take heavy big rid traffic and are wavy and undulating (up and down), so that riding them is like riding a series of small ocean waves. If I drive too fast on these roads, my car can nose-dive ocassionally (what does this mean? front struts are wearing? it passed the bounce test, perhaps springs?)
Does anyone know where I can find specs on the stiffness vs. comfort, or just your opinion of the ride, of these shocks:
KYB GR-2
Monroe Sensa-trac
Monroe-matic
NAPA Response
The NAPA website has specs on their own and the Monroes, but I am having hard time finding specs on the KYB's.
Specifically, how does compressed length, travel length affect ride?
How do the gas pressures compare? I know that in general, that these are all low pressure shocks.
I have not found any high pressure shocks that specifically fit this vehicle, but I may be able to use another one that has a cross-reference. I emailed that supplier already with these questions.
I can't speak for the Napa shocks. Aside from that, I would choose the GR-2s. They are the only affordable shocks I've seen that are tubular, and not seam welded rounded flat metal.
I went to the local NAPA store with what I found online at NapaOnline. It appears that the NAPAs are rebadged, competitively-priced Monroe shocks. But taking your advice and the results of a bit of research on this site, I went with the KYB GR-2's in the rear. If they work out on the rear, I'll get GR-2-based struts for the front.
Were you able to find any reviews for the struts? Maybe tirerack or amazon would sell them and have user reviews. I guess you could try a google search for "NAPA Response review" ect and see what comes up.
I went to various sites, TireRack, DiscountPerformanceAutoParts.com, PerformanceCenter.com, and ReplacementShocks.com among others. Some of these sites had very simple review feedback, and I found only three reviews for a late 1990's, early 00's Corollas LE on the GR-2's on TireRack (correct me if you find them), but more for Honda, Mercury, Acura, Chrysler, etc. reviews. In addition, I read almost all the reviews for the Gas-a-Just and Monomax shocks on TireRack and on other non-Corolla forums (like JeepForum.com) -- enough that I felt that it was okay to take a gamble on trying out GR-2's. I thought about getting the Gas-a-just shocks, but their price was more than my budget at this time.
My shocks haven't arrived yet, so I can't tell you about them. I'll let you know how they work out. If not, I'll get either the Monroe Sensa-trac or the OEM shocks -- 1stToyotaParts has the best price on OEM shocks.
Incase you havent tried them yet check out http://www.rockauto.com because they usually beat 1sttoyota in prices.
I just installed GR-2s on all 4 wheels and they it seems are great. More sportier and seems to be more stable then what I had before. Mind you, my previous shocks were completely dead, as they did not expand once compressed. It is crazy to think I was practically only riding on the spring as 3 out of 4 shocks were useless.
Do you have a lot less body roll now during hard turns or is the difference small?
Yes, I have a lot less body roll in turns. I can take turns faster with more control. I also feel like my brakes and overall stability has improved.
One thing is that my car has no sway/stabalizer bar. Overall I am very satisfied. I paid extra for good shocks and I learned to instal them myslef on through this form and by googling. Well worth it.
I'll have to get the GR2's then once my struts take a crap. I dont like this sloppy suspension.
I wonder if a strut bar, in addition to a sway bar, would make handling better.
I went to the junkyard the other day (looking for a jack part for my other car VW, which is kaput) and saw two Corolla GTSs with strut bars; I measured their lengths but they seemed too long to fit my Corolla. In retrospect, I should have snagged one, and then cut it down the middle and then weld it to make it fit. I know I could get an aftermarket strut bar, but the thought of having an OEM one seemed to good to pass up at the time. Needless to say, I did not buy the strut bar. They're probably gone now.
Strut bar will sharpen steering, especially with wider wheels, but otherwise - does not help handling that much.
I would passed on the GTS bars - welding them to fit doesn't make too much sense (weakens the metal, too much hassle for return in performance). Though, you could have probably resold them online for a slight profit and used that money to get a new strut bar.
