I was thinking more on the line of - the car is light and in emergency type braking, requires a long distance to stop.Perhaps the stock tires have little traction for quick stops.
Of course if the brakes are worn or out of adjustment, stopping distance is affected.
How often do I stop on the interstate?? Pretty much everyday.
Have you seen California traffic??
People drive like idiots - stop for no reason - panic stop because they see someone put on their brake lights, etc.
The point I was trying to make is that older Corollas seem to have more front-end collisions than mechanical problems that take them off the road.
I did see an older Corolla that had been rear-ended (indicates it stopped too good and got hit from behind???), but most have front-end damage.
Do you stop from 70MPH on a daily basis? If you do, I don't think you can really blame the brakes on a Corolla. Any non performance computer is going to get brake fade from that kind of driving.
You can always just upgrade the front brakes and 4 tires and be done with it.
Rear drums aren't that bad. Most of the braking is taken care of by the front brakes. Also, rear disk can sometimes cost a lot to replace. Most if not all modern cars have a drum style e-brake in the middle of the disk. It's like a two in one.
Also, reading the first post, the guy locked up the tires. Doesn't sound like bad brakes. Sounds like bad tires and or a bad driver.
I don't think you can accurate data on ow the brakes are just by how many you see front end damage. Rear ends are almost always due to bad drivers. Sometimes bad weather, but almost always from people tail-gating, driving too fast, or just not paying attention when traffic stops in front of them. I've seen it over and over before. It's even happened right behind me before. People get all pissed cause I leave a gap, and then when traffic stops, I can stop and the car behind me can stop, but then BOOOOOOM!!!!!!!! Perfectly dry roads with sunshine too.
