I have a 99 CE auto with 121k. I have been reading about all the oil burning problems and mine uses no oil. IT has been a great car but it is giving me front end problems. My wife is pushing me to sell and get a new car but i would like to push this one to 200k. I am about to quit my job to go back to school so i need to get this thing in tip top shape before i cut my income. I have posted in other forums so I am going to do the ole cut and paste. I would like to fix just the problem areas instead of wasting time and money repairing the non problem parts. A little history: MY mother bought the car with 10k miles, always dealer serviced and maintenanced. I purchased from her with 100k and did the typical 100k service oil, belt, plugs, wires, trans filter and fluid, brakes, etc. I am not a street racer i drive responsible and the car only is driven hard when it is a must(like getting on with moving traffic) but nothing abusive. I hope this helps!
When I hit a series of small bumps There is a rattle from the from the front 2 wheel areas. It sounds like the struts are bad. I replaced 1 front strut and went on a test drive to see if the problem was corrected and the sound is still there. Before I replace the front passenger strut I would like to know exactly what is wrong so I can replace all at once. Could this possibly be a the wheel hub bearings? I have never had a Toyota do this so I am unsure. IF anyone has replace the front wheel bearings, is the hub sold as a unit with bearings?
"How is the rattle? I mean, is too loud? or is just like a screech?"
Its really hard to explain. It is not a screech or a squeal. It sounds like something is loose. I have had old trucks with bad wheel bearings and (on a jack) the wheel hub could move back and forth(toward the engine bay and away from the engine bay) when you shook it with your hands. The sound is similar to that. Turning a worn out CV shaft back and forth will make a similar sound. The sound is not to loud like something is about to break but at the same time it is not so quite that you have to turn everything off to hear. It has been doing it for a couple months. I am about to go back to school and I will be on the road a lot so I need to get this fixed ASAP. Any help will be appreciated.
I really need about 1.5 years of good service without major disaster in the automotive area. I will be driving about 150 miles a day.
