Guest Speedmaster
Hello,
I own a Toyota Corolla (manual 5-speed transmission) (chassis number NZE120) (1.3 VVT-i and Year 2001) which I imported from Japan. Its cluster only has a speedometer, a fuel meter and a temperature meter. I recently bought a cluster from ebay having a tachmometer in order to fit it in my Toyota. As soon as I removed my original cluster and fitted in the new one, I started the engine and noticed that the tachometer worked. However the cluster illumination did not work when I turned on the side lamps and headlamps switch. Its a pity that my new cluster cannot be seen in the dark. I consulted my Toyota authorised agent here in Malta where I live and I have been told that I have to change the whole wiring system which would involve me in a lot of expenses. Is it possible that just to make the cluster illuminate, I have to change the whole wiring system?
Can anyone please help? Perhaps a diagram with the cluster pinouts can help in order for me to trace exactly the pinout that has to do with the illumination. If anyone has the diagram with the pinouts, I would appreciate having the pinouts for the NZE120 cluster (without tachometer) and the NZE121 (i.e. a Toyota with 1.5 engine) cluster (with tachometer).
Your help in this matter would be GREATLY appreciated, please.
