hello i have a 89 toyota corolla le and was wondering if there is any performance parts i can get for it or anything i can do for descently cheap...
by Phoenix, April 21, 2007
Probably not a whole lot. Get a manual and see what stock compression is and see if you are close to new.
If so, a full tune up (plugs, wires, all fluids and filters, and a new cat, maybe even high flow). Then you could replace any suspension parts that are worn, get new rubber, and overall, just try and make the car feel more new. Hit up the brakes too.
When you are dealing with a older car, no matter what it is, you need to do a lot of up keep before you attack any performance parts.
