Don't know - I'm pretty sure he's a good driver given the number on his time slip (RT, 60' time, etc.) But that is what he runs on average - anyone can crack off a couple of good ones, some days your car just "feels" stronger.
Wheel hop will kill most runs, even with sticky tires - if you have to feather the gas - your run is done, not enough torque to run it back up there. If you only get a hint of wheel hop with the stock motor - just think how much there will be if you add 75HP on top of that. Adding just a bit more power does not equal better ETs - you have to be able to put down the power effectively. If the tire was able to hold - maybe 14s with a 75HP shot. Easier to put good runs together if you are little shy on the power - takes more variables out of the equation.
But numbers are just numbers - you can put down some killer numbers - but average them over a period of time and you'll get a better feeling for what the car can do (more consistent runs). I've been driving competitvely for years - and every once and a while, I get a bad run here and there. Get a little cross-wind halfway up the track, you just lost a couple of tenths off your ET. Get a little sand on there inside of the 60' mark, run is down an easy 1 second in the ET. Even my bone stock CRX with 13x5 wheels and 90HP would put down low 16s runs trapping at 83-85 MPH all day long. Every once and a while, get a good tailwind - ET is touching the high 15s. Get a strong head wind - opps, run is now looking like 17s.
16.3 in the quarter is well above average (ie. faster ET than average) for what you have listed. What's your 60 ft times and trap speed look like? Running a 1 way, 1.5 way, or 2 way LSD?, What do you mean by 8K springs - the spring constant, k or some other metric?
