Was unable to confirm this, on the very new Corollas, there is a cleanable MAF sensor, but , on the 96 model, is there a similar sensor that can be cleaned .??
by lexicon1, November 17, 2006 in Pre-1997 Toyota Corolla and Geo Prizm
1996 Corolla is MAP based - 2000+ Corollas are the ones that use MAF. Cannot clean the MAP sensor, but you could try cleaning the throttle body up and check the PCV system - those tend to improve idle behavior dramatically.
Was unable to confirm this, on the very new Corollas, there is a cleanable MAF sensor, but , on the 96 model, is there a similar sensor that can be cleaned .??ThanksBe sure and check your air filter and clean the intake tube. You can also use carburator cleaner to help clean of stuck carbon deposits.
