When I worked only two miles away, I rode my bicycle back and forth to work.
I also rode it 12.5 miles at lunchtime and then 20 miles after work.
I did that for four years and really got in shape.
I also participated in several organized century rides and did a couple of time trials and triathlons (just the bicycling portion).
One year I put 4200 miles on my bicycle (more miles than on my car).
I even did a double century ride or two (two hundred miles in a day).
I turned all my fat into lean muscle and really felt healthy.
I don't know where I got all the time, but lately I don't seem to have as much.
DANG!!!! bikeman, wow!
are you retired? I mtb myself but no matter how long I ride, I still remain 5-10 at 200lbs. I can currently bench 160lbs and curl 60lbs. As for my quads, hamstrings, and calfs, well, I just let my mtb'ing take care of that. But, I still weigh in at 200lbs. Nobody believes I weigh that much though, people go so far as to calling me a liar and I only say that to get attention. My belt size is 36, is that too large?
My arm flexed is about 14" in circumference
I also coached soccer and played some myself. I used to play roller hockey and then swicthed to ice hockey when an ice rink was built nearby. I still play.
I did do some mountain biking, but really liked the road better.
Anything that has you using a lot of aerobics and increases your heart rate will help you.
In addition to everything you can do for your body, there are genetic influences that factor in how much you weigh, what your body profile can be and also how you will look.
My suggestion is to work the specific areas of your body that you want trimmed - in a gym with specific equipment and then continue aerobic exercise to increase metabolism and heart rate.
Weight lifting will reduce fat, but muscle is heavier, so your overall weight might not become significantly less as your fat turns to muscle. Weight lifting is also not very aerobic and you would do well to supplement it with an activity that is more aerobic. I always liked sports as a means to do that.
