A short ram generally will not help with high alititude conditions. There is a slight chance that the car will not "see" the extra air volume coming in and it will feel like that there is more power. But with the 2ZZ-GE being a MAF - chances of that happening are pretty close to zero.Thanks for the feedback. If 6k rpm valve issue has to do with the air density a mile above sea level, are there work arounds to this? Example: Will a short ram intake help the extra valves kick in sooner?Thanks
Short of reflashing the ECU for factoring the difference in air density - there is not much you can do. Unlike older carburators that can be rejetted for alititude or atmospheric changes - FI meter in what the sensors them them. You can try different octanes (lower).
For those that don't know or need more info: What is the effect of altitude on engine performance?
- Reduced air density provides lower combustion temperature and pressure.
- Fuel is metered according to air volume, consequently as density decreases the Stoichiometry moves to rich, with a lower octane number requirement.
- Manifold vacuum controlled spark advance, and reduced manifold vacuum results in less spark advance.
Generally for modern engines - to help performance, reduce the octane by about 0.2-0.5 points for every 300m of altitude change (1 mile ~ 1600 meters) - So if car calls for 87 octane - 1 mile up - you need to 84 or 86 octane.
Good Luck.
