(Sorry if this is a repost, I haven't seen these specific questions answered in depth.)
There are two jack points on each side of the car for use with the tire changing jack in the Corolla's trunk.
Q: Is it safe to use your own floor jack or jack stand with these same points? My guess would be not because there is a ridge of metal at these points that looks like it might bend or break if you use anything other than the jack in the trunk with the special contoured receptacle. In which case...
Q: Where are the safe points to use when jacking up one entire side of the car - in case you are rotating the tires on one side for example. If you use the trunk jack at one of the factory designated points, where would you place your floor jack or jack stand? The only other jack points I see in the manual are at the center-front or center-rear of the car, neither of which would safely raise the left or right side of the car at a time (rather they would be good for raising the front or rear or both at the same time).
Thanks!
