Guest KnifeEdge_2K1
Hello all I'm new on the forum and I'd like to thank all of you in advance for your help and guidance.
Over the past few months I've been taking my sister's car (2001 Corolla CE 4-speed Canadian spec 136 000km on the odo or 80 000 miles) to school. Its a rather short trip about 3 kilometers but it beats walking in the winter and heat in the summer. The problem is after my first couple of fillups I started noticing how much gas the engine consumed, I did some research on the internet and found that the 2001 engine should use 7.8L/100KM while my average for 4 fillups has been 11.1L/100km, now I'm not an aggressive driver so I'm confused and unable to locate the problem. I've checked the air filter which is fine and added some fuel injector cleaner into the tank at my last fillup (I'm still using that tank of gas, btw the fuel injector cleaner i used is about 3 years old so it might have lost it's effectiveness, ill buy a new bottle for my next tank of gas)
The only other fault that I can think of that would cause this kind of decrease in economy (using 43% more fuel) is a faulty oxygen sensor, faulty injectors, or faulty sparkplugs/wires. All of which I cant check ( i cant get under that black plastic thing that covers the plugs and wires, i dont want to remove it since i dont know what's under it. I know that in winter the fuel economy is expected to decrease but 43% is a bit too much, my friend who has a 2003 avalon only experienced a 15% drop from his rated fuel economy from 11.1 rated to 13.4 L/100km.
Please advise, I'm the one paying for fuel and it's getting to be a real pain since i have to save as much as i can for university.
P.S. sometimes when i stop and idle the engine makes a loud vibrating sound which goes away when i shift into neutral or start moving again, this doesnt happen very often and I think its due to bad engine mounts
P.S.2 I've read the review on the corolland site for my model corolla and it says that the interior noise is relatively quiet, in my car under even mild acceleration the engine seems quite loud, i do not have a tachometer on the car so i cant tell what the engine speed is, id estimate it at about 2500-3000 rpm when it shifts up
