franklinpug
2013 AC stopped working
The AC on my 2013 stopped working today. Fan motor runs fine, and the ac light comes on, but all i get it hot air.
I had a similar issue with my old 2003 Corolla, and an AC relay replacement did the trick (which I learned about on this forum). With the 03, I swapped the horn relay for the AC relay just to test. I want to do the same with the 2013, but none of the relays are labelled in the manual or the fuse box under the hood.
Can someone help me out?
