smug
Rattle Check Sequence In 04
Hello, 04 corolla has front end rattle. At 96k new struts,ball joints , control arm bushings, wheel bearing/wear checked, sway bar bushings r/r. now 109k, well maintained. With this in mind, can those in the know give me a sequence to check front end components and narrow down and eliminate causes. Thanks.
Delayed responce,  When  Chicagoland winter eases will check sway bar end links, and inner tie rod ends.  Replace sway bar bushes while back.  Narrowed rattle down to hitting a bump at specific angle.  Thanks dom.
