Opium
Control Arm Bushings
Just the bushing or the whole arm?
Haven't run into too many brands out there for replacement bushings, so whatever you can get your hands on, probably is OK.
I've heard of that brand from trolling the Club Lexus forums - they seem to be well received on that site.
Every time I break hard, making the tires skid, I can hear and fell a jerk from the left front side. As if something rocks forward around the wheel. Also, when I slow down from anything above 50 mph,
when pressing the brakes, theres major vibration. My tires are good, balance and aligned. My rotors and brake pads are good. Can this be a sign of a control arm
bushing or motor mount?
Yes, it could absolutely be a bad front control arm rear bushing.. Check both your driver and passenger side front suspensions' control arm rear bushing for ripping or unbonding by prying it up and down with crowbar and with front end jacked up and wheel removed.
Edited by dom
That's good. Are you replacing it yourself? Front lateral bolt could be very hard to remove. Try spraying some penetrating fluid on its threads through chassis openings first. You're replacing only the driver's side control arm?
Edited by dom
How did those bushing look like on the driver's side? Were they dry rotted / damaged? Possible that it could get better when you replace the passenger side as well. Sometimes its really difficult to judge a bushing's condition until you get it unbolted from the chassis/part.
Could be movement in a number of interconnected components - bad hub, worn wheel bearing, slop in steering rack, worn tie-rods, worn bushings, worn engine and transaxle mounts, bad lower ball joint, worn strut mount, corrosion compromising the unitbody (cracks, broken spot welds, rust perforation), etc.
