cirrus
Heater Issues(Civic)
Hi guys.....always great well thought out advice here(like the intake gasket on my 2005 rolla) so told the wife I'd ask here even though its not a Toy but should be an issue any car can have.
Our 2002 Honda Civic has this issue when its idling and the heater is on...the air is cool....yet get the motor rev'd a bit and its nice and hot.
Its never overheated....runs great at 122K miles....no loss of antifreeze....no antifreeze in the oil. The dealer said right away......"heat gasket". I was floored!
I thought maybe bad thermostat though then I'd think I'd see that on the temp gauge....or something in the heater core. They said probably not.
Why would a head gasket cause that????
Could a bad radiator cap cause it....or thermostat?
Any ideas to check on be great!
TIA
Cirrus
Edited by cirrus
Could be a number of things. T-stat is the first thing that pops into my mind - faulty T-stat could be partially working, so the car won't overheat under normal conditions, but won't provide hot air. Waterpump could be going, not able to circulate the coolant as effectively as it should. Vacuum leak - not sure if this year Honda uses a vacuum source to control the blend air doors in the HVAC system. Cooling system could have a bubble in the system, more so if you've just had a cooling system service or if the coolant recovery tank ever ran dry. Plugged or damage heater core + hoses running to it could also be a cause for issue.
Blown headgasket - unlikely. For a blown headgasket to cause your heater to act in that manner - has to be guzzling coolant. Since coolant levels seem good - engine temps are OK - this is very unlikely. Dealership sounds like they want to pry some extra money from you. The definitive check is an used oil analysis to check for the presence of coolant in the oil and a coolant test to see if hydrocarbons have bubbled into the coolant. Without those tests - you can't say a blown headgasket without any sort of certainty.
Caveat - there are a fair number of 7th gen Honda Civics that have seen blown headgaskets, especially if the miles runs past 100K miles. More likely to see this when it gets closer to 200K miles. Usually the first sign is that the car is loosing a significant amount of coolant.
Hi FIsh...thanks very much for the reply...just in time too.....the dealer is finding a lot of stuff wrong with it....thing has an external oil pump???
But they want $3000 to replace like everything...head gasket and a ton of parts with that....the exhaust manifold has a leak (and of course the CAT is part of it) and this and that.
What is irrating me is I'm guy who likes to diagnose stuff fully. Do a leak tests of the cooling system....do a block test for gases in the exhaust....check the flow from the water pump. They haven't done that and said their tech is 99% sure its the head gasket. He might be right as like you said this is a common issue. Or is this like...same model car....bad struts at 40K miles they had everyone replacing. I balked...no way....and at 122K the can is fine with those....no tech says they are bad. So who knows if these head gaskets were really bad.
To me I cant see it being the head gasket! Its not overheating...nothing looks to be in the oil and its not using antifreeze. Oh....good one there...they said to me...."its low on antifreeze too". I filled it up actually abit to much in the over flow yesterday....and I watched the radiator run....it always had antifreeze flowing up near the cap. When I dropped the car off...same level.
Lets say we keep driving it....and its the gasket....if it does start putting it into the oil that can really screw up the motor right?
TIA!
External pump!? Only if you mean it sits on the engine instead of inside the engine. This gen's Honda is not any different than on the Corolla. Sounds like this dealership is living up their namesake of "stealership". They want to just shotgun the repair - don't diagnose anything, just replace parts on your nickel until they magically "fix" the problem. Worse case, they actually do a diagnostic, find the trouble part - but still charge you for all the other unnecessary work to pad the repair bill.
I'd try another dealership if possible - or if you have access to a good independent shop - have them do a diagnostic. Much of the chemical testing, you can do yourself. Used oil analysis companies can send you test kits to sample your oil, ship them the sample, and wait for the results. Same way with coolant sampling - some actually give you the chemicals to mix with coolant to see if there are traces of oil and/or hydrocarbons (pH testing).
Playing Devil's advocate - say it is a bad head gasket - if you kept driving, it will eventually contaminate the engine oil (see engine oil take on an unusual color, look like frothed chocolate milk) and you'll blow coolant everywhere (gases get into the coolant, and push past the pressure cap easily). Even then, the car might run for a couple of thousand miles no problem. If it see something catastrophic, like a cylinder filling up with coolant and you blow a rod though the block - it will still cost you less than $3K the dealership wants to "fix" your car and swap in a replacement engine.
That's what bothers me....I asked what tests the tech has done....just a few simple ones but he is 99% sure its the gasket. I suggest the other tests but they balked saying it gets costly. Now the issue is....as I told my wife...I cant ask them to do the tests as they'll never say..."hey you were right...its the water pump or thermostat...". Nope...like you said...they'll change that part but still do the head gasket saying it was that. THe guy who did the water pump/belt didn't use a Honda one...which is no big deal....but he might have used a cheap one that maybe now is falling apart on the impeller side.
Also they said for sure if the head comes off it needs to be machined down so he set that up with a local shop. Funny how fast they feel they need to do that....like they know something about this issue and whats coming?
Maybe he's right....and its that....the service guy is great guy and has helped us out before....but I just like more testing done first.
So....we are getting the car back tonight....and I'll see about getting a 2nd opinion.
But also this has been going on with the heater for like 2 months now....if its blowing into the cooling system I'd think I'd see it coming out the over flow at some point by now.
If its sucking it into the motor I'd see it sucking the radiator dry....right?
So I'll keep a close eye on it.....what oil testing labs do you guys use for the oil?
Thanks for the help!
Edited by cirrus
Yeah, if there is any loss of coolant, whether it is being blown out cooling system or consumed by the engine - your coolant recovery tank should be changing levels by a considerable amount. When it gets to the point where it affects the level of coolant in your radiator's tank - then that is bigger/worse problem. Usually, if you are consuming coolant, you'll get a sweet smelling exhaust odor and there will be a prodigious amount of white smoke produced as you drive.
I've used Blackstone Labs for used oil testing - http://www.blackstone-labs.com/ - standard tests run about $25 per sample, they will send you a free sampling kit if you request one (two plastic containers and mailer). You can pull a sample through the dipstick tube (have to purchase their suction kits or use something you might have at home) or drain some of the oil from the pan, taking a sample after the first couple of seconds of draining (easier to grab a sample, oil flow will be reduced).
I agree with your - they seem to be way to eager to point this to a bad head gasket. Either they know something we don't know - or they are just going on what they've seen the most lately, possible quotas, etc. Testing being more costly is pretty hard to believe - unless they can show you definitive signs that the head gasket is blown (ie, the more time you waste, means it will cost you more money down the road). The radiator hydrocarbon gas test is pretty quick. The last time I saw one - it was at NAPA. Looks like a clear plastic tube filled with blue liquid (dye) and a rubber stopper in one end, aspirator bulb on the other. You jam it into the neck of the radiator after the car has been warmed up. Squeeze the aspirator bulb a couple of times to pull any gas out of the radiator / emissions from the coolant. If the blue dye turns yellow - you've got gases escaping into the coolant. For oil tests - send out the sample, takes about a day for them to test it, depending on how backed up they are on their queue. I usually get my results emailed to me within 48 hours of sending the sample to their shop.
Oh yea if the motor starts guzzling antifreeze you will see it!!! I once had a cylinder crack and the smoke screen I left was HUGE....I mean as high as the telephone pole wires and wide as the road!! Cars behind me had to stop completely! One guy raking his lawn was laughing so hard as I stopped in front of him saying...."man I've never seen a motor grenade like that before!!".
Blackstone even allows me to just send oil in from my end without their kit. Cool...I have special capped bottles I can use...same some mailing time.
I don't get that either with how long testing would take. I've seen Utube videos on using those block tester kits....whats the big deal? I think Advanced and NAPA even rent them out....look into that tomorrow.
I'll get these tests done and keep a close eye on everything.....they might be right...but I need more testing yet to say go ahead with the job.
Thanks for all the help!
No problem - let us know what you find out! Even though this is for a Civic - the testing and diagnostic tests would be the same for other manufacturers. Good Luck.
For sure I'll let ya know as something is going to happen unless we trade it in and I let them fix it. I've been net searching for this issue and I see a lot of issues like this but a lot less updates on what fixed it. Some have said its the head gasket....others the water pump. That is where I think it might be but doing that isn't cheap either.
I was reading the report after getting the car. He says its burning the coolant internally. There is a fairly reputable indie garage down the road from me that deals mainly with Honda's....see him on Monday.
But I've been trying to really understand this....I'm just rambling here......
....at idle the heater air is very cool....the minute the car idles it goes cold but the minute you race the motor its hot air again. At first I thought for sure a vacuum leak but from what I'm reading this car doesn't use that method to control the blender door.
It its the gasket what the heck is happening? If its pushing air into the cooling system something has to come out. The overflow unit.....can just air go into that or does coolant have to go with it too?
I'm going to run the motor and look for tiny bubbles in the antifreeze via the radiator entry....I'd think if I see anything there it probably is the gasket. I don't get it though if it is....and there is this air bubble in there....why would it go from hot to cold back to hot that fast?
The tech says its burning it. Okay I'll watch the level but seeing anything in that overflow is almost impossible even using a light. Wonder how high should it be in the radiator with the cap off it? He said it was low this morning. I find that VERY hard to believe as when I ran the car on Monday night....there was always coolant over the fins in the radiator and the over flow....when I could see it...was at min when it was cold and I ran it with the cap off and hot and again the coolant was right under the radiator cap opening.
But if it is burning it....how the heck is that affecting the heater? Plus I'd think it'd be backwards...heat at idle nothing once the motor is reving away as it sucking in the coolant like crazy.
OTOH....cars can be very weird with issues......so......more news soon....:)
Compression test might show if you have a head gasket leak or not. Sometimes, you'll get bubbles to actually run out the radiator neck during this test - but usually, it has to be pretty bad to get to this point.. As for coolant levels in the radiator - I've always seen it run to the top of the neck of the radiator, no air pockets. If the level is just barely covering the fins of the radiator - might be a coolant leak,
As for heat only when revving the engine and cold at idle - could be either a bad water pump (damaged impeller), or as the tech mentioned, bad head gasket (air bubble could be trapped in the cooling system). Honda's are picky about these cooling system parts, aftermarket waterpumps can corrode very quickly.
If the impeller is damaged, it will not be able to move enough coolant through the system and through the heater core. If it was a head gasket, there could be a bubble of exhaust gas pushed into the cooling system. Have to rev the engine to get enough pressure from the water pump to push that air bubble out and through the heater core. With both issues - it will be almost a "light switch" effect of going from cool to hot air.
Could pull the plugs and see what they look like. Even the tiniest bit of coolant leaking into the combustion chamber will contaminate the plug - depending on what else was deposited in there, a coolant contaminated plug may look unusually clean compared the other plugs. Might also have a shiny appearance. Many times, there will be a break between cylinders and you'll see two adjacent plugs that look visibly distinct compared to the other plugs.
Here is a good description of different HG failures on Honda/Acuras and possible diagnostic approaches.
http://www.honda-acura.net/forums/accord/202091-faq-head-gasket-failure-symptoms-and-testing.html
Hmmm....I cant "quote" your reply......anyway....
Right now...and the when I first checked it last week....the coolant was over the fins but not really right to the bottom of the neck. Maybe I should fill it and watch it. One big issue is I cant see the level in the over flow tank....I cleaned it...used a flash light...rocked the car...cant see it....unless its empty??! Issue is if I add some to it and its to much it cant be drained without removing the whole thing. Don't even think I can snake down a piece of thin flexible hose.
I too thought if it was pushing air into the system via the head gasket then a bubble might be in there. It doesn't have a bleed valve anywhere....so I ran it around without the cap on...up some hills....to see if it would push the air out of it. Then if it did....and the issue came back with that would point to a head gasket I figured. But that didn't solve anything.
The tech said its burning the coolant....hmmm...if the bubble theory holds as far as why its causing this issue...how does sucking coolant in cause that? At some point sucks in air via the over flow?
The former non Honda tech who did the water pump I believe used a NAPA one....that's who caters to our local small garages and he for sure he uses them. Issue is getting at the pump is not easy as it runs off the timing belt.
I might see try the block tester....our local store has one....about $40 to try it....might tell me if its leaking. And watch the fluid level...at some point...esp if it sucks the overflow dry....its going to start showing via the radiator.
I found that exact link last night and was reading it. Only thing he didn't have was what this tech said....coolant leak into combustion chamber.
The tech might be right....but unlike with my Corolla where my dealer (I have an excellent deal with them) told me right off with that code...don't go changing the O sensors or MAF....its the intake gasket for sure...we've done several of these on the 2005's....the Honda tech isn't saying if he in fact has seen this happen a few times hence him wanting to skip all the tests.
What I might have them do is skip this so called leaking oil pump that he says is on the motor block....the leaking exhaust manifold( it does have a crack) that has the freakin CAT attached to it and costs $1100.....and just do the head gasket and water pump/timing belt. But first drive it and keep an eye on it.
Edited by cirrus
Shouldn't suck in air at the overflow - unless the tank is bone dry. If there is a leak into the combustion chamber - water will be siphoned into the cylinder under vacuum and exhaust gases pushed out on compression/power - that's where the air bubble will come from.
Wouldn't hurt to fill the radiator tank to the brim and monitor if the level drops any. Assuming the system is completely purged of air - it should not drop any. If there is excessive pressure - it will blow it into the overflow tank. Might be a useful test to see if the overflow is empty - if it is, leave it that way and see if coolant makes its way into the tank. That would indicate a possible air bubble pushing its way through the cooling system.
NAPA aftermarket parts are actually pretty decent. Lots of dealerships and independent shops will use NAPA parts if they cannot get OEM.
DUH my part with the compression....of course. I think the tech saying it was just sucking it in had me off on the wrong path.
For sure have some stuff to try here....and if it does end up being the gasket that's okay....at least now I wont feel like I had to make the call at that very moment on what is a lot of money for a 11 year old car. Esp seeing how I've been eye balling the new Rolla's....or a older Camry.
I'll post what I find and in the end what happened!
Mini update Fish: This morning after the car sat all night a 5F I took the cap off and started it and let it run with the heater on. The coolant was down to the bottom of the neck. Within minutes...even before it was warm...several big bubbles came out...and it spit antifreeze out of it. I let it run...a few more bubbled then it stopped. I took it for a ride...got it real hot....came home and took the cap off. Wasn't under any pressure to speak of.
But I did notice one thing...I didn't see anything in the overflow....so I removed its tube and blew into it. And there wasn't anything inside of it. Hmmmm. So I added antifreeze to bring it up to minimum level and watch it today and tomorrow.
The whole time the gauge never went above half way. Later today or tomorrow I'll see if the parts store has that block tester.
Edited by cirrus
Update #2
We took a 2 hour ride.....the coolant was right on the MAX mark....we get back and its down about 1/2" in the overflow tank. That's not much...but maybe it is sucking in some. I'll run it more tomorrow and see if it keeps going down. If it does I guess its not the waterpump/thermostat....probably the gasket.
Create an account
Register a new account
Sign in
Sign In Now
