Guest tankhardrive
How Do You Veiw Cel Codes?
Guest tankhardrive
hi my girl friends CEL light has come on and ive been looking all around to find how to bring up the OBD and cant find it.... i've never delt with her car before she has a 2005 corolla.... so yeah if someone can just let me know how to bring up the OBD that would be great so i can see whats wrong with it....
thanks in advance.
thanks in advance.
I believe you need an OBDII scanner.
Welcome to the forum.
Yup, Bikeman982 is right - you need an OBD-II scanner to read the codes. If you are thinking of buying one - also make sure that it is also CAN protocol compliant. Previous Toyotas used an ISO protocol, then in 2005 model year Corolla - they switched to the new industry standard CAN protocol. Most scanners, now, support multiple protocols, but it is a good idea to double-check.
Another option is to take it to an Autozone, Advance Autoparts, or similar autoparts retailer - many will read the code for free, but not reset it (they're not supposed to erase any codes - an insurance issue).
If I had a newer Corolla, I'd like to get one of these.
Scan Tool
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off "Check Engine" light
* Make and store up to 10 rewritable special codes to send to the vehicle computer
Digital Gauges - Shows 4 gauges at a time from the possible following:
* Fuel Economy (MPG - gasoline engines only)
* Fuel Rate (GPH - gasoline engines only)
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
Trip Computer
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used (Gasoline engines only)
* Trip Fuel Economy(Gasoline engines only)
* Distance to Empty
* Time to Empty
* Fuel to Empty
