Guest simduf15
Accessories For Corolla 2001
Guest simduf15
Hello everybody,
I just want to know where I can find some accesories for my corolla 2001 LE
I search something like
- the clock in the dash
- speed regulator
- electric window
In fact I want some accessories that is avaible on the corolla 01 CE but I don't want to sell my car to buy a another 01 CE
Thank you
Welcome to the forum. Easiest way to get the in-dash clock, cruise control, and power windows is to find a donor car at a salvage yard or similar and remove the components you need. You probably will not find those parts anywhere else, other than a dealership. You could also go the aftermarket route - they do make universal systems that will add those features to a car that originally did not come with them - but will: 1. not look nearly as good as the factory install, and 2. may not work as well (a function of being universal). If you pick up those parts from the dealership - be ready to pay a small fortune. Best bet is to find a partout Corolla with those bits - and start swapping parts. The hardest part would be the power windows - as they do not share many parts with the manual version - be almost easier (possibly cheaper) to replace the entire door than swap the parts you need, then resell what you have left over to recoup the inital investment.
One word of caution - doing this may require carefully realigning the doors. Depending on how able you are to perform delicate work (with some oddly shaped wrench I might add) swapping parts may be easier.
Junkyard is your friend. Tell them enough and they will figure out you're doing a swap (or retrofit) and try to upsell you. :lol:
Guest simduf15
Thank you for your help. I should check in the salvage yard around my region
Create an account
Register a new account
Sign in
Sign In Now
