Just Turned 160,000 Miles
I drive a 2005 Toyota Corolla CE that was purchased in 2004 for the 2005 model year. So far it has 166K. Lets see what has happened to it, almost over rev'd when I was stuck in snow, drove about 5km with no trans fluid, no 4 tires are presently alike.
My 2000 Corolla VE was sold in 2004. When it hit 156K.
That's a lot of driving. Unless you bypassed the ECU, it will prevent the engine from over revving.
It was probably just revving high, but not moving anywhere. It seems like the engine will blow due to the noise, but that would be normal at high speeds.
My last Toyota was a 1987 Pickup with a 22R 5 speed. It had 480,000 miles when I sold it (big mistake) and the valve cover had never been off it. It still ran good and strong and only burned a little bit of oil, about a quart every 1500. The original clutch was replaced at 450,000 miles because it was slipping a little when towing my 19' bass boat up steep grades. My current Toyota is a 2002 Corolla CE, 3 speed auto. It has 99,000 miles on it now, still runs like brand new and doesn't use any oil to speak of. If it goes half as long as that pickup I'll be happy. I don't know if the 1.8L motor is as bulletproof as the 22R but I'm assuming it is. As far as I know a Toyota with 160,000 miles is just getting broke in good.
That's what I think. I am hoping the 1.8L motor will last forever.
I have seen some that broke thru the block due to a broken crank or bearing.
Try telling someone not familiar with a Toyota that they can go for many miles and most won't believe you, since they are used to American cars that are lucky to get 100,000.
I am trying to sell my 1997 and people are interested - until they hear that it has over 230,000 miles on it, then it's goodbye!
Is that the original belt or was it replaced sometime earlier? If it looks good I guess I'd keep it. If its cracked I'd replace it.
It is the same belt that it had when I bought the car from e-bay about 2 1/2 years ago.
I have not looked at the belt, but thought that preventive maintenance suggested it be changed every 60k miles.
That would make 180k an interval of 60k and time for a new belt.
Personally, I will look at it and see if it needs changing, rather than change it regardless.
Edited by Bikeman982
My parents 1994 Corolla DX has 490,000. :)
That's incredible!
I have seen high mileage Corollas, but that is certainly a lot.
Have they replaced the engine/tranny or any major parts?
