corranhorn 0 Report post Posted September 19, 2006 My oem exhaust manifold had a crack in it so I replaced everything from that manifold back, and decided to opt for a stainless steel racing header (4-2-1), hi flow cat, and catback exhaust/muffler. However, since replacing the exhaust it seems hotter under the hood that it did oem. In fact the strut bar and intake pipe are pretty darn hot when I check them immediately after driving at normal temp. I could have sworn I followed the directions on the exhaust wrap to a "T" when I wrapped the header and the downpipe. I've always read/heard that exhaust wrap was supposed to keep your engine bay cooler....I had assumed they had meant "...than stock". Is it supposed to be hotter now, with a wrapped header, than it was with stock exhaust? Here's pics of it... Looks the same as every other pic I've seen: http://i68.photobucket.com/albums/i38/corr...derWrapped1.jpg http://i68.photobucket.com/albums/i38/corr...derWrapped2.jpg http://i68.photobucket.com/albums/i38/corr.../EngineBay1.jpg Either way my intake pipe gets hot, which helps to negate the idea of an aftermarket intake if it's just sucking in hot air. What can I wrap the intake pipe with to help keep the intake temp down? I was thinking about just using the exhaust wrap, but the last thing I need is fiberglass up in the filter. Thanks for your suggestions! Quote Share this post Link to post Share on other sites
fishexpo101 13 Report post Posted September 19, 2006 Yup - unless you get the header thermally coated inside and out - no amount of heat wrap will help pull those temps down below stock temps. Just the price you pay for a better exhaust. If it is that hot now - just imagine what the temps would be like with no wrap!! That is what they mean by reduced underhood temps - not compared to stock setups. Not much you can do for the SRI - I wouldn't worry about it too much, the temperature differential from ambient outside air and under hood temps is not that much. Once you get air moving there - it will be much cooler. The only issue you will have is with heat soak at a dead stop or very low speeds. Only way around that is to go with a true CAI setup and insulate the intake tract or go with an ice box design (kind of like a box that seals against the hood and all around the sides of the filter to insulate it from direct heat). Remember - will all that you can do with the SRI or CAI intakes and insulating them - once the air hits the TB and intake manifold, it will be hot again. A wrap will only provide insualtion for the pipe - the filter will still suck in hot air. The amount of heat transferred from the intake tubing to the incoming intake charge is pretty much neglible - air will form different temperature boundaries inside the tube, most of the air will go through without being heated at all - only the portion that is closest to the tube will be heated and only slightly at that. Really paranoid about wanting a cooler intake charge and don't want to use a wrap ore replace the setup - try water injection. A proven method to cool the intake charge and works great with S/C setups which don't have any other method to cool down the intake charge. Just do a search for Aquamist, Snowperformance or similar - makes more sense on a forced induction project, but can be used in a N/A application. Quote Share this post Link to post Share on other sites
Bitter 1 Report post Posted September 19, 2006 my engine bay isnt any hotter than it was before with my wrapped header, but before the top heatsheild on the stock manifold was off. it had been loose and rattly so i took it off. the wrap is amazing stuff, i can TOUCH the header with my fingers for a second and not be burned. after a long drive, the hood is only slightly warm, it gets hotter sitting in the full sun all day! Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 Yup - unless you get the header thermally coated inside and out - no amount of heat wrap will help pull those temps down below stock temps. Just the price you pay for a better exhaust. If it is that hot now - just imagine what the temps would be like with no wrap!! That is what they mean by reduced underhood temps - not compared to stock setups. Not much you can do for the SRI - I wouldn't worry about it too much, the temperature differential from ambient outside air and under hood temps is not that much. Once you get air moving there - it will be much cooler. The only issue you will have is with heat soak at a dead stop or very low speeds. Only way around that is to go with a true CAI setup and insulate the intake tract or go with an ice box design (kind of like a box that seals against the hood and all around the sides of the filter to insulate it from direct heat). Remember - will all that you can do with the SRI or CAI intakes and insulating them - once the air hits the TB and intake manifold, it will be hot again. A wrap will only provide insualtion for the pipe - the filter will still suck in hot air. The amount of heat transferred from the intake tubing to the incoming intake charge is pretty much neglible - air will form different temperature boundaries inside the tube, most of the air will go through without being heated at all - only the portion that is closest to the tube will be heated and only slightly at that. Really paranoid about wanting a cooler intake charge and don't want to use a wrap ore replace the setup - try water injection. A proven method to cool the intake charge and works great with S/C setups which don't have any other method to cool down the intake charge. Just do a search for Aquamist, Snowperformance or similar - makes more sense on a forced induction project, but can be used in a N/A application. An ice box or cai is the only reasonable choice, but no ice boxes are made for the 7th gen (that I can find), and cai a may look into, but probably not. I read up on the water/methanol injection - very fascinating stuff! I'd consider getting it if I had a twin turbo Supra or something, but it'd be ridiculous for a corolla. Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 my engine bay isnt any hotter than it was before with my wrapped header, but before the top heatsheild on the stock manifold was off. it had been loose and rattly so i took it off. the wrap is amazing stuff, i can TOUCH the header with my fingers for a second and not be burned. after a long drive, the hood is only slightly warm, it gets hotter sitting in the full sun all day! I can touch it for a second or so too without a burn, but the strut bar and intake pipe are up there in temp too. I've felt the top of the hood immediately after driving - it's way more than slightly warm. I can't remember the last time I put my hand on my black car on a bright sunny summer day but I can't hold my hand there for too long after a drive. No, I don't race around or anything - I rarely hit over 4500 rpm. I also have checked all the exhaust connections: they're all tight, no leaks. I'm not overly concerned about the extra heat. Mostly just gathering information, as this is my first project car and I have money here and there to dump into it, for no other reason than to learn. I can't wait until winter now...I won't have to brush off the hood ever! Quote Share this post Link to post Share on other sites
Bitter 1 Report post Posted September 19, 2006 hmm. are you sure you overlapped enough? i overlapped 1inch for each wrap of my 2" heat wrap and i went all the way to the bottom of the header. http://img.photobucket.com/albums/v335/huz...ne/e225bf75.jpg http://img.photobucket.com/albums/v335/huz...ne/821eb290.jpg Quote Share this post Link to post Share on other sites
Bitter 1 Report post Posted September 19, 2006 (edited) hey, how much of a difference have you noticed with the header, in terms of performance. Edited September 19, 2006 by Bitter Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 hmm. are you sure you overlapped enough? i overlapped 1inch for each wrap of my 2" heat wrap and i went all the way to the bottom of the header. http://img.photobucket.com/albums/v335/huz...ne/e225bf75.jpg http://img.photobucket.com/albums/v335/huz...ne/821eb290.jpg Holy crap - 1in overlap? Crap! I could have sworn it said 1/2in... I'd check the box but I threw it out. I still have the extra wrap though. Yup looking at your pic yours is definately overlapped more than mine. Darn, I was hoping my exhaust project was done. Since it's a two piece 4-2-1, I can just take the header off and rewrap thank God. hey, how much of a difference have you noticed with the header, in terms of performance. I played around with it quite a bit the first two weeks... Lost a little low end torque, but a very noticeable increase in 4000rpm+ hp. IMO worth it. I do mostly city driving so my dead stop to 40mph, or highway 55mph is a whole lot better. I did a lot of gear hops - 1st to 5500/6000, 2nd to 5500/6000, then straight to 4th to keep it at speed. In the 25/30mph zones I'd do 1st to 3rd. Good times. It's louder than I'd like, but it's a very low deep tone. Quote Share this post Link to post Share on other sites
fishexpo101 13 Report post Posted September 19, 2006 Depends on the wrap - how wide it was to begin with and if you had to pre-soak it or not. I had some 1" and 2" exhaust wrap - both had to be overlapped by about 1/4 the width on the 1" and about half the width on the other. Was way easier working with the thinner wrap - messy, came with some weird type of heat paste smeared all over it - but was thin enough to wrap around the maze of pipes pretty easily and curves and bends were nothing. The wider wrap worked pretty well too - but around bends, it bunched up a bit (if you made it look good) - was a plain fiberglasss wrap, no goop on it. Quote Share this post Link to post Share on other sites
tashirosgt 0 Report post Posted September 19, 2006 I'm curious whether the statement on http://www.stahlheaders.com/faq.htm to the effect that wraps reduce the lifespan of headers is true. Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 Depends on the wrap - how wide it was to begin with and if you had to pre-soak it or not. I had some 1" and 2" exhaust wrap - both had to be overlapped by about 1/4 the width on the 1" and about half the width on the other. Was way easier working with the thinner wrap - messy, came with some weird type of heat paste smeared all over it - but was thin enough to wrap around the maze of pipes pretty easily and curves and bends were nothing. The wider wrap worked pretty well too - but around bends, it bunched up a bit (if you made it look good) - was a plain fiberglasss wrap, no goop on it. I used the 2in fiberglass wrap without any goop - had to pre-soak. I had 1in and 2in - I must've read the 1in box and assumed just to wrap 1/2 instead of reading the 2in box. Mine bunched up quite a bit around the bends, so around the bends it's more overlapped than on the straighter parts. Oh and what's that string stuff you used to tie it down? Looks to be more easily manageable than hose clamps. Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 I'm curious whether the statement onhttp://www.stahlheaders.com/faq.htm to the effect that wraps reduce the lifespan of headers is true. I've read it so many places I'd say yes. What I've read makes sense to a certain extent, too. Here's another one: http://www.centuryperformance.com/heatwraps.asp Just also keep in mind the sources. I can explain anything I want, any way I want, if I'm selling something. Quote Share this post Link to post Share on other sites
twinky64 0 Report post Posted September 19, 2006 How damaging is the increased heat focalized to the headers going to do? With all the heat being kept on the exhaust headers, wouldn't they fail sooner? Quote Share this post Link to post Share on other sites
corranhorn 0 Report post Posted September 19, 2006 The reason I went the stainless steel header and wrap route is because this is my first experience with either - If I screwed up or didn't like it I'd be out a $102 ebay header, not a $250/$300 ceramic header. How damaging is the increased heat focalized to the headers going to do? With all the heat being kept on the exhaust headers, wouldn't they fail sooner? With my ebay header in particular (because there's no way to know what kind of crap metal it's made out of) I'm betting yes. Quote Share this post Link to post Share on other sites
Bitter 1 Report post Posted September 19, 2006 (edited) i dont know what kind of wrap you guys are buying.... i used DEI 2" wide wrap and overlapped it 1", which is more overlap than recomended. there was no soaking, no goop, just a fiberglass wrap treated with some chemicals. i used bailing wire to tie it down, just wrap it around once and give it a tight twist with a pair of pliers, clip the excess, then tap the little tab of metal down flat. the header runners are made from 304 grade stainless and im not sure what the flanges are made from. Edited September 19, 2006 by Bitter Quote Share this post Link to post Share on other sites
