Guest edmontecillo
Coolant loss
Guest edmontecillo
I own a 96 Corolla Gli. Lately i observed that coolant from my coolant reservoir gets depleted. The radiator and hoses are fine. Where did it all go? I'd appreciate any tips. Thanks.
Any white smoke comming otu he pipe??? Have you changed the oil lately? Did it look unusual? If you have a leaky head gasket, the coolant can end up in the oil. You might see that you oil level is increasing.
Try placing a piece of carboard under the car to see if it's dripping out slowly. Sometimes pihole leaks on a hose are hard to see or feel for.
It's also possible that there is a leak in the radiator. be sure to keep refilling the overflow no matter what you do and check it often.
Edited by Cherry128
