Guest unrealii
Supercharger!
Guest unrealii
Just discovered that trd made an sc for the corolla:
• Maximum HP gain @ 6750 RPM = +40HP
• Maximum torque gain @ 4000 RPM = +38 ft.lb.
http://www.trdusa.com/ for details
Kinda pricey at $2995 :o but doesn't void factory warranty :D
Although I would prefer the celica gts engine and trans in the corolla for 3 g's.
Looks like with the torque boost in the midrange, the Supercharged corolla could make a good run with a stock Celica GTS. Hmmmm.... looks interesting. I wonder how much it hurts mileage? Depends if the comptuer can keep the car runnign lean. IF the max gain is 38 @ 4000... and the torqu curve is relatively flat with the VVTi, then I'm guessing peak torque is around 150-155.
I might have ot seriously look at this, sounds like a great way to make a fun little sleeper car or make it haul A** with a trailer.
