Jim
POWER TRAIN:AXLE ASSEMBLY
DESCRIPTION:
ON PASSENGER VEHICLES WITH VEHICLE IDENTIFICATION NUMBERS (VIN) STARTING WITH 1NX ONLY AND BUILT FROM JANUARY 8 THROUGH FEBRUARY 13, 2002, IT IS POSSIBLE FOR THE BOLTS THAT JOIN THE REAR BRAKE AND HUB ASSEMBLY TO THE REAR AXLE CARRIER TO BE LOOSE DUE TO INSUFFICIENT TIGHTENING DURING THE ASSEMBLY PROCESS.
CONSEQUENCE:
IF THE VEHICLE IS OPERATED IN THIS CONDITION, ONE OR MORE OF THE FOUR BOLTS COULD COME LOOSE, CAUSING AN ABNORMAL NOISE FROM THE REAR AXLE AREA. IN THE EVENT THAT ALL FOUR BOLTS LOOSEN COMPLETELY, SEPARATION OF THE REAR BRAKE AND HUB ASSEMBLY FROM THE REAR AXLE CARRIER COULD OCCUR, WHICH COULD LEAD TO A LOSS OF VEHICLE CONTROL.
CORRECTIVE ACTION:
DEALERS WILL PROPERLY TIGHTEN THE BOLTS. OWNER NOTIFICATION BEGAN MARCH 21, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT TOYOTA AT 1-800-331-4331.
