How To Replace Intake Manifold Gasket
5 replies to this topic
#1 HeadDent
HeadDent
    1st Gear
  • Pip
  • 19 posts
Posted 22 January 2012 - 02:23 AM
Hey guys,
I've been kicking around here for a while trying to find information on how to replace the intake manifold gasket for my corolla. I purchased the car back in July, but in the winter months I have discovered the crazy rev hunting issue on very cold starts (overnight, 30F > ). The car has 53,XXX miles, so it is still pretty young. I have read many places that the Intake Manifold Gasket is often to blame for this cold start problem. Regardless of whether it is or not, I can be almost certain that the gasket has not been replaced before. That whole area probably needs a good cleaning as well. I already purchased a replacement gasket from the dealer, but that is as far as my project has gone.
So I was wondering if anyone would be so kind as to direct me on how to do this. If there is already a topic discussing this then I have not seen it. But if there is forgive me for missing it.
Thanks!
#2 dom
dom
    04 Corolla CE 5spd
  • PipPipPipPipPip
  • 1237 posts
Posted 22 January 2012 - 04:56 AM
The original intake manifold black gasket was revised with # 1717122060 orange silicon gasket. It's only about $7 in Canada.
TSB EG045-07: http://www.toyotapar..._T-EG045-07.pdf
1st pic shows elusive brake booster vacuum hose on intake manifold, which is hidden once throttle body is installed... Intake manifold gasket was easily replaced on friend's 2005 without draining any coolant or disconnecting throttle body coolant lines, by setting (+cleaning) throttle body aside.
Posted Image
Posted Image
Edited by dom, 22 January 2012 - 05:03 AM.
#3 dom
dom
    04 Corolla CE 5spd
  • PipPipPipPipPip
  • 1237 posts
Posted 22 January 2012 - 04:58 AM
Posted Image
Posted Image
Edited by dom, 22 January 2012 - 05:04 AM.
#4 HeadDent
HeadDent
    1st Gear
  • Pip
  • 19 posts
Posted 22 January 2012 - 12:10 PM
That's great! Should make or break for me.
I have a few more concerns before getting started though. What kind of lubrication (if any) should be applied to the gasket or gasket seat before reinstalling the manifold? Also, will throttle body cleaner be best for the manifold? Finally, the gasket I received is SKU 17171-0D020, and is a black gasket. I did see an orange gasket offered by RockAuto noted as 'revised'. However, I decided to go OEM and order from the dealer because of my inexperience. Is that going to be a problem?
Much appreciated
#5 dom
dom
    04 Corolla CE 5spd
  • PipPipPipPipPip
  • 1237 posts
Posted 23 January 2012 - 08:39 AM
No lubrication for the gasket. It's installed clean and dry. Throttle body cleaner would work for the manifold and to clean mating surface on engine head too, as well as the throttle body and MAF/IAT sensor.
Your Toyota dealer is supposed to provide you with the new revised orange gasket # 1717122060 (current part number) as per TSB EG045-07 (Oct 27 2007). SKU 17171-0D020 (previous part number) is the same problematic gasket that's already on there and leaking. For some reason, they're both listed in Toyota OEM parts... Have your Toyota dealer exchange it for the proper one (1717122060 $5.62 retail).
Edited by dom, 23 January 2012 - 11:07 AM.
#6 dom
dom
    04 Corolla CE 5spd
  • PipPipPipPipPip
  • 1237 posts
Posted 23 January 2012 - 08:16 PM
"Part number 17171-0D020 supercedes to part number 17171-22060. The old part number will still work in the search box, but it will end up being substituted by the new number when your order is processed.
Best regards,
-Dan
1stToyotaParts.com"
