My Other Car...
122 replies to this topic
#121 Bitter
Bitter
    Overdrive
  • 3029 posts
Posted 03 March 2017 - 08:46 PM
Exhaust seemed loud, the gasket between the muffler and midpipe I put on a few years ago is coming apart and making some noise, I'll have to see if I can fix that Monday but until then I can just turn the music up louder. I'm fairly confident that 600W RMS can drown out a partly absent gasket.
Driver side headlight has a distinct double cutoff and is dimmer, some kind of shield issue, contacted the AliExpress seller with some photos to see if they'll warranty one and send a replacement or if I can just buy a single unit. I think I'm outside any warranty but it doesn't hurt to ask. I might end up blowing money I don't have on some MiniD2S 4.0 projectors now that I know they'll work (these are the Chinesium versions with a different cutoff shield, but same bowl and what not), they're a bit wider, the cutoff is aluminum so I can re-work the step if I want to to make it less huge cause it's huge and I'm not a fan of a huge cutoff step. It is kinder to other driver especially if I'm going to continue running them at 45W. With some low hour used Philips 85122+ in these projectors at 45W the light output is even more staggering than with the Yeaky and Morimoto bulbs. Almost halogen in color but just TONS of light, amazingly bright and I'm outshining anything driving along with me on the road by double or more.
#122 Bitter
Bitter
    Overdrive
  • 3029 posts
Posted 11 March 2017 - 12:00 PM
My exhaust pipe came, a day late from Amazon Prime but not actually a day late because tracking said it would be a day early. Anyway, came at the tail end of lunch, I managed to put one entirely too thick coat of VHT Flameproof flat aluminum color paint over all the welds and flanges. I'll put a second coat on Monday morning at work and try to put it on during lunch that day if there's a rack free. The pipe has broken away and it's pretty annoyingly loud, it sounds like a non vtec honda with a resonated straight pipe.
#123 Bitter
Bitter
    Overdrive
  • 3029 posts
Posted 17 June 2017 - 11:50 PM
Exhaust pipe was a stinker to do, broke a bolt and had to grind some others off that wouldn't come and couldn't heat due to the gas tank and drive on rack being in my way. I've checked it a few times since and the VHT paint seems to be holding up well, no rust on the welds anywhere yet, see how winter treats it. The muffler will fail next, the top has some ugly spots that I slathered with muffler cement to keep things silent for the time being. Flex section is taking a poo at the moment, I've got a whole ebay header that should fit for $30 shipped, fingers crossed, otherwise it's $90 for a flex pipe.
Ran some X66 top end cleaner through, made a big big difference in how smooth it idles and runs overall. Did some steam cleaning but probably too short a duration, the misfires were making me worry about the cat converter. Running some TWC3 marine 2 stroke in the fuel at 640:1 ratio (1oz/5gal) as it's supposed to help combat/prevent carbon build up and quiet the engine/smooth the idle even more, skeptical but it's cheap to try and a bunch of people swear by it. The X66 top end cleaner though, that made a huge difference. Sucked some through PCV and then poured some on piston tops and let it sit for 3-4 hours then sucked the piston dishes, cranked with plugs out till fairly dry, then started it up with only a little puff of smoke and drove it hard with lots of WOT at highway speeds. Idle was immediately smoother when I came back home with it.
