My Other Car...
114 replies to this topic
#106 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 03 October 2016 - 12:12 AM
I like the clay cloth, did as good a job on a fairly clean car as Mothers clay did but in much much less time, 1/3 to 1/4 of the time. I'm not sure how well it works on a heavily contaminated car but I can find out at some point. I'm hoping it mars less than Mothers does my black Celica with it's stupid soft paint.
476 is from my limited experiences a great wax, easy on, easy off, sheds water and dirt incredibly well. I'll find out this winter how well it stays put, I'll do one last clay down and wax before winter salt hits and then that's all it gets till spring unless the wax protection fails over the winter.
#107 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 06 November 2016 - 09:00 PM
I went to change the air filter in the Mazda because the rubber seal around it was bad. Found some old droppings and urine in the bottom of the air box. Pulled it, found chicken wing bones and more urine/feces under it. Put the car out, soaked it with cleaner, soaked the AC condenser and radiator with cleaner, let it all sit, scrubbed the top of the trans and soaked it a few more times, rinsed it all till clean and no more purple/red response from the urine with the cleaner, washed the air box out the same, added better water drain holes, ran it without filter/box till the fans came on to dry some stuff up, pulled it in, gotta put it back together now. I L O V E my underhood light. I could not have seen that or done the cleaning at night without it.
Got a nice MANN filter on close out from RockAuto for like...pffft nothing. I'll go put it back together later on, not the first time I've had mouse issues but now that it's cleaned up and garaged on the regular should be the last of it. It's been sitting out the past month almost while I worked on my aunties 91 Capri turbo...but this mouse stuff was older than that, likely left overs from when I lived at the apartment and parked by the dumpster 2 years ago.
A while back I bought a single 6 Osram LED spot pod to tinker with, not so bad output but nowhere near the claimed 30W output. I finally boosted it by altering the sense resistor for the driver from 8W total current consumption to 23W total consumption with a peak temp at 70F ambient and no air flow of 140F which is acceptable and there's little visible droop in output as it heats up. It seems fairly stable. I bought a 2nd one just today to do the same boost to, I intend to swap them in place of the cosmetic yellow fogs and wire them as high beam assist/driving lights that'll come on automatic with high beams but will still have a disable switch so I can manually elect to not have them on with high beams.
Which brings me to the other recent event, the 15 year old foglight wiring I installed when I was about 16 went up in smoke, I think something shorted inside the pass side fog light as it seems to have burnt from there upward but didn't get out from in front of the radiator and luckily I was standing still idling when it happened. For whatever reason the 20A fuse just melted it's case but didn't blow, it could have been one of those recalled Chinese imposter fuses that looks like a fuse but doesn't act like one. It came with the cheap fogs a long time ago, whatever, no true harm done to the car so it's OK. I'll rewire it all when I swap in the spot pods to see if they can be useful down that low or not. Hopefully the can be, they're a very tight spot beam so fingers are crossed. If they aren't useful then I'll repair the yellow halogen fog lights if possible and reinstall those for winter and save up pennies for some Hella MicroDE projector fogs. __________________
#108 fishexpo101
  • 10,058 posts
Posted 21 November 2016 - 10:32 PM
Yup - those rodents love to hide out in those areas of the car - at least it didn't get inside and start shredding the interior.  One of my old muscle cars, chipmunks and mice stripped all the foam and jute from the seats - nothing left except the vinyl covering and springs underneath!
Ouch - luckily it happened the way it did and that you were there when it happened.  Always a good excuse to come up with a nice upgrade.
#109 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 24 November 2016 - 02:44 PM
The engine light popped on 2 days ago with a P0141 and then last night it went back out again on it's own, I need to inspect the wiring but it's probably the original sensor at 145K miles. A NTK OE replacement is about $40, not bad.
#110 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 24 January 2017 - 10:20 PM
Engine light hasn't come back on since, I'll worry about when I worry about it, got other things to fix in the mean time. Also re-doing the headlights, finally got some projectors that fit and light well and weren't too expensive.
Projectors
https://www.aliexpre...0608.0.0.xqxN99
Shrouds
Duplicates of what I have now that I'm eh about, use them flipped upside down from how they go in a BMW.
Waiting on some of the shrouds to come in. Test fit the projectors in my spare headlight and they seem to sit level unlike the last pair I tried forever to get to work right. Hopefully this will be a quick retrofit this time! I'm pondering seeing if I can polish a clear circle in the stock headlight lenses and re-fit the correct model year 1998 lights and side markers or not, would be kind of fun for until I have the 00-02 bumper painted, I'll get it sprayed and put on when I get the leading edge of the hood fixed.
#111 fishexpo101
  • 10,058 posts
Posted 25 January 2017 - 02:00 AM
Decently priced - stuff looks good so far.
Yeah, getting them to sit level is always tough - sometimes you get lucky and they just work out.  That was NOT the case with my Matrix - I eventually gave up and got an OEM set to replace the ones I chopped up.  Might try to print something out on my 3D printer, once I get a replacement hot end for it, to serve as a better temporary bracket next time.
#112 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 25 January 2017 - 08:44 AM
I think the key this time is that the supplied rubber washer is cut so badly (both are), they're totally lop sided and acting like a shim to push the projector up into place. I bet I could get the last set of projectors to work if I used these washers too but as I later found out they're prone to have issues with the metal parts expanding and the high beam shield getting stuck either on or off or in between. Bending the channel it rides in can help but then sometimes it doesn't return to the right spot to be in focus totally. I'll probably mod them a little to fix the shield issues and give a friend some retrofit headlights since I've got two sets of this projector with nothing to use them in.
Unless I end up messing with some of my spare halogen Celica head lights and put bixenon in the hacked up high beam bowl and see if I can get the high and low beams aligned or something. No idea, but it could be fun, but again I have no use for that and probably couldn't sell them for what I spend on them time wise.
#113 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 31 January 2017 - 08:37 PM
Tiguan shrouds or something, they snap right onto the D2S 3.0 and these 4.0 Clone projectors, a couple dabs of JB to make sure they don't go anywhere and I'll be set! I like how they look better than the E46 shrouds and the E46 don't snap in place. Win/Win I think. I'll set about making sure the aim will be correct on the car this weekend and then do the pigtail for the harness and try to find some bulb caps. I lost whatever came with these head lights if any came with. Once I get things sorted out to make sure it works right I'll order the driver side head light but probably go ahead and install the passenger side and ride around crooked eyed for a week till I do the other side. I don't give a **** how stupid it looks, it's the winter beater.
I also like that I get less stray light with these shrouds and projectors, what stray light there is comes off at even steeper and less likely to annoy angles than what I have now. I appreciate the slight housing fill that the shrouds product, it's nothing like an M45 shroud does but it still gives the whole lamp some light.
639D4AC8-8008-4A36-A69C-8E581088ACFF_zps
1C59D7E8-E697-4182-9952-E8232A1EF273_zps
#114 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 08 February 2017 - 10:25 PM
Wow doesn't even approach the difference between my old stuff and this stuff. Same bulbs, same ballasts, pass side is new housing and new projector, driver side is my old stuff. I think the rotation is just slightly off on the passenger side, it might have shifted when I was working on it or something, I'll see if I can correct it without opening it back up or not but I should probably either fix it right or leave it alone cause there's a greater chance of me making it worse than there is of me making it better if I try to short cut.
AFA74BE4-F8CC-47CB-9096-6F9B54D8FCB8_zps
8D9D5155-9ABC-4E3E-957C-077BF865FAE5_zps
I tried the crooked silicone washers with the 3.0 projectors in the old pass side headlight for grins, they still put the beam through the wrong part of the lens so no matter what I did the 3.0 wouldn't have worked out for me in these headlights. So odd...
But I think I'll hack up some 7x6 housings and stick the square 3.0 projectors in them and put them on my dads Jeep YJ as a fathers day gift when he's up this way around May this year. He'll like that quite a bit and being D2S bulbs are readily available.
#115 Bitter
Bitter
    Overdrive
  • 3,015 posts
Posted 13 February 2017 - 08:55 PM
Washed.
Waxed.
Sunshine.
Oh and some output shots too! Low and high beam.
