Corolland Forums: Brake Light Coming On? - Corolland Forums
Page 1 of 1
#1 User is offline   Sonix Icon
  • 1st Gear
  • Pip
  • Group: Active Members
Posted 01 November 2009 - 10:36 AM
My brake indicator light was coming on when I started the car, but went off after a few stops and starts. Well it stopped coming on, do I need to worry?
Not the brake lights on the outside of the car. 1998 VE.
Btw, I can't buy Honorable Donor / Karma Builder. No payment method with no options to add one!
This post has been edited by Sonix: 01 November 2009 - 10:41 AM
0
#2 User is offline   madar601 Icon
  • 2nd Gear
  • PipPip
Posted 01 November 2009 - 04:58 PM
Check your brake fluid level, and if it's low, add some, then check for any leaks. If your front pads are worn pretty good, then it's naturally going to look low.
0
#3 User is offline   fishexpo101 Icon
  • Group: Global Moderators
Posted 03 November 2009 - 03:55 PM
Exactly what madar601 said - probably low fluid levels causing the brake lamp to flash intermittently like that.
Also, if you haven't replaced the brake fluid in the system (brake fluid flush), might be a good idea to do so. I try to get one in every other year or 30K miles or so. Doesn't take very long for brake fluid to absorb enough moisture to cause problems. More of a preventative thing than anything else. A good time to do it is when you need to replace the brake pads - since you'll be working around that area anyways.
0
Page 1 of 1
