03 Water Pump Leaking
#1
Posted 28 July 2009 - 04:56 PM
Can I do the work myself? or is it too tight of a spot to do.
Plus I have an oil leak which is dripping on the ground and the oil is covering my ?a/c compressor? not sure--- it is in the far back, by the firewall and at the bottom. got an idea if the gasket is leaking on the engine or something else???
FYI I have 70k on my rolla.
other is brake time-- got any recommendations on front brakes pads and rotors?
#2
Posted 29 July 2009 - 05:40 AM
#3
Posted 29 July 2009 - 09:27 AM
Oil leak, have to find the source - dorman pointed ou a pretty common leak area on lots of 9th gen Corollas, the timing chain tensioner o-ring. Also double check around the valvecover - another spot that could have a likely leak. Best thing to do is to wipe up as much of the oil as possible, and suspect areas - then monitor closely for the start of the leak. Possible that the leak originated else where and just made its way to the A/C compressor.
Brakes - depends on your driving style. Hard to beat OEM brakes - composite material, quite and smooth operation. Ceramic pads have been well liked on this board. Many also like a more aggessive pad, like Hawk HPS, Porterfield, EBC, Carbotech, etc. - more initial bite, strong fade resistance, and still gentle on rotors. Just do a quick search on the forum, lots of topis on different pad choices.
#4
Posted 29 July 2009 - 03:06 PM
Dorman you are right-- that is the power steering pump. Links are to the images of the car. I was unable to insert images.My 2005 with 48000 miles on it has had the same "pink crust" by the weep hole area for about 2 years now. I never had to add anything, I guess the leak is so small that it only leaves the pink crust. As for the oil leak the only common thing I have seen is the timing chain tensioner o-ring. This tensioner is on the left side of the timing cover if you are looking at the engine from the belt point of view. If your looking at the front of the car its near the passenger firewall area by the power steering pump.
first picture is the pink crust. It isn't where the repair manual says the weep holes are.
pink crust
next two pictures are regarding the oil leak. It does look to be in the area of the timing chain tensioner assy. but it looks like it may be the seal of the timing chain cover. whatcha' think?
1st is under the car photographing up
oil leak from bottom
2nd is on top of the engine photographing down/side.
oil leak from top/back
What does it take to replace the O rings? (just remove both bolts or a lot more complicated than that?)
Edited by Lee614, 29 July 2009 - 03:13 PM.
