Security Indicator Light On
6 replies to this topic
#1 Guest_magicbane_*
Guest_magicbane_*
  • Guests
Posted 12 February 2007 - 08:19 AM
I have a 2004 Corolla S and just recently I've noticed that my security indicator light is on all the time. It's on when the car is off, when I start the car and when I'm driving. Does anybody know what this means? I've checked the manual and it makes no mention of this. Any info about this would be greatly appreciated.
-Bane
#2 goatmonger
goatmonger
    1st Gear
  • Members
  • Pip
  • 34 posts
Posted 22 February 2007 - 05:19 AM
Did you bother to check with the dealer/service center? Your car should still be under warranty. Even if it's not, they can probably answer a question like that pretty easily, right?
#3 Bikeman982
  • 9,229 posts
Posted 22 February 2007 - 09:49 PM
Sounds like a short, but it could be a system malfunction.
#4 Brendon
Brendon
    4th Gear
  • Members
  • PipPipPipPip
  • 689 posts
Posted 23 February 2007 - 12:35 AM
Is there actually a security system in? On my Mom's Corolla, she has a security light that blinks, even though there isn't really a much of (if any) a security device installed. My mom thinks its for show to scare off potential intruders since the light blinks in a very visible way from the driver's window, even if the doors aren't locked.
#5 Bikeman982
  • 9,229 posts
Posted 23 February 2007 - 12:39 AM
-Bane
Is it on steady, or flashing??
#6 the99contour
the99contour
    5th Gear
  • Members
  • PipPipPipPipPip
  • 1,485 posts
Posted 25 February 2007 - 08:32 PM
If your Mom's Corolla is a 2005 or later, that light isn't for show, and the car does have a security device on it. The key is encrypted, and that light indicates the status of the system. Off= disarmed, blinking= armed and steady means initializing or malfunction depending on whether it is on steady when you are starting the car or if it goes on steady and stays on all the time. Steady while starting is fine, other wise, they system isn't working.
The encryption means that the car has to have the encrypted keys in order to start. Trying to hot wire the car is pointless, because no matter what wires you cross, the fuel pump isn't pumping unless that encrypted key is present in the ignition switch.
The blinking light also serves as a break in deterrent, statistics prove that cars with visible security indicators such as blinking lights and stickers are less likely to be broken into, regardless if they have such a system or not.
#7 Bikeman982
  • 9,229 posts
Posted 26 February 2007 - 01:36 AM
It is true that cars with security lights and stickers (put a few on your car) get stolen less than cars without them.
