04 Corolla Serpentine Belt Replacement
16 replies to this topic
#1 vurjt
vurjt
    1st Gear
  • Pip
  • 47 posts
Posted 12 June 2006 - 09:36 AM
When does Toyota recommend changing the serpentine belt?
I have 80k miles on an 04 Corolla LE with AC and AT. Belt looks great and occasionally squeals after driving in the rain for a while. Teflon spray takes care of the squeal.
Also, last fill up yielded 41.5 mpg.
#2 Max
Max
    5th Gear
  • PipPipPipPipPip
  • 1587 posts
Posted 12 June 2006 - 09:48 AM
I can't remember right off hand when it's supposed to be replaced. Did you look at your owner's manual?
#3 fishexpo101
  • 10076 posts
Posted 12 June 2006 - 01:15 PM
At the very least, change it when it needs it - if you notice checking, missing ribs, frayed edges, or excessive squealing - time to change it. Cracks running perpendicular to the longitidinal ribs are normal. Some owners get as little as 25K out of belt - some can go 100K or more on the same belt - depends on driving conditions, age, amout of ozone belt is subjected to, etc.
Belts are pretty cheap - if in doubt, change it and keep the old one in the trunk as a spare. Simple, under 30-minute job perfect for a DIY job with basic tools.
#4 vurjt
vurjt
    1st Gear
  • Pip
  • 47 posts
Posted 12 June 2006 - 02:15 PM
Thanks fishexpo101!
The OEM belt was $60 at a local dealership. Checked two dealers both priced the belt at $71 but one gave a 15% discount to beat the other so I got it for $60.
I drive all highway miles, 1.5 hour commute each way morning and evening.
#5 Bikeman982
  • 9230 posts
Posted 12 June 2006 - 11:56 PM
Thanks fishexpo101!
It doesn't sound like the belt was cheap, unless that price also includes the labor for them to change it.
#6 arens
arens
    1st Gear
  • Members
  • Pip
  • 33 posts
Posted 13 June 2006 - 01:34 AM
I check the belt every 10k miles or so. I usually change the serpentine belt at about 60k miles unless there is abnormal wear. Once I get my Gates belt on I have never had one show early wear on any vehicle I have owned.
That price from the dealer is too high. You should be able to pick up a Gates or Goodyear belt from an auto parts store for between $30 and $40.
#7 vurjt
vurjt
    1st Gear
  • Pip
  • 47 posts
Posted 13 June 2006 - 04:53 PM
I mis-quoted the price. OEM Toyota belt was $25.64 including tax.
#8 jimb29635
jimb29635
    1st Gear
  • Pip
  • 37 posts
Posted 12 August 2006 - 08:52 AM
Had to replace serp belt on 2005 CE Corolla, because of extreme noise. I thought it was a bearing at first, but it was the belt. Only 36k miles.
#9 Bikeman982
  • 9230 posts
Posted 16 August 2006 - 01:33 AM
You might have cured the noise with teflon spray and saved the belt for another 36K.
#10 SIRNEMO
SIRNEMO
    1st Gear
  • Members
  • Pip
  • 16 posts
Posted 20 August 2006 - 11:57 AM
Forgive my naive, what kind of teflon spray you use?
Brand?
Where you get it?
#11 fishexpo101
  • 10076 posts
Posted 20 August 2006 - 12:13 PM
They label them as "belt dressings" - helps in some cases, but with the issues the 8th and 9th gen had with belts - I'd just go ahead and replace it versus a temp spray.
#12 Bikeman982
  • 9230 posts
Posted 20 August 2006 - 05:34 PM
Brand?
Where you get it?
I have not used it myself, but have read where others have cured noise by spraying it on. It could also have been spray from other than automotive applications (such as for cooking). It is just a suggestion and the ideal solution is to determine the extent of wear on your belt and act accordingly. It could have become worn and hence, the cause for excessive noise - therefore it requires replacement. It also may have just needed some tension adjustment and that would be a simple fix. The teflon spray may have been able to cure the noise, or maybe it did need replacement.
Edited by Bikeman982, 20 August 2006 - 05:35 PM.
#13 azsunlover
azsunlover
    1st Gear
  • Members
  • Pip
  • 23 posts
Posted 22 August 2006 - 02:51 PM
I live in Arizona, so I would probably be changing mine more often (25k miles) due to the extreme heat and dryness. Last thing I need is a serpentine break in 110 degree heat out in the middle of nowhere.
#14 Bikeman982
  • 9230 posts
Posted 23 August 2006 - 01:21 AM
The last thing you need in Arizona is to break down anywhere. Don't you run the A/C all the time and go from A/C'd cars to A/C'd buildings and back?? You would get pretty hot if there was no A/C.
#15 scottystang
scottystang
    Neutral
  • Members
  • 8 posts
Posted 20 September 2006 - 10:01 AM
My wife's 2004 Toyota Corolla S w/ 47k miles has a squealing sound coming from the engine. The belt looks ok, but I don't really know what I'm looking at.
I'd like to change the bely myself. Is it an easy task for a novice DIY'er? I don't have any "special" tools either, just the basics. Should I give it a try?
