Rear Discs?
12 replies to this topic
#1 dogdenii
dogdenii
    1st Gear
  • Members
  • Pip
  • 10 posts
Posted 03 January 2005 - 08:47 AM
Pretty simple questions. I've searched here and on other boards and on google and I can't seem to find anyone who has switched to Discs in the rear.
Thanks in advance.
#2 fishexpo101
  • 10076 posts
Posted 03 January 2005 - 10:43 AM
Anything is possible - most common way to do it is to part out a donor car with rear discs. Popular models are Corolla GTS, Celicas, MR2s, Levins, etc. You could go with a new MR2 - but that would be quite costly. Wilwood can also make a custom system for you - but the cost to performance would be dismal.
Good Luck.
#3 dogdenii
dogdenii
    1st Gear
  • Members
  • Pip
  • 10 posts
Posted 04 January 2005 - 09:54 AM
Good Luck.
Good information.
Is there a write-up using donor car parts anywhere?
Did the corolla come out in 99 with discs on any of the models?
Thanks for the reply.
#4 tinto99
tinto99
    3rd Gear
  • PipPipPip
  • 338 posts
Posted 04 January 2005 - 01:45 PM
I doubt any of the 99 models cam eout with rear discs.
My 97 did not (of course that is 7th gen), but 8th gen is not much more sophisticated, as is the current gen.
#5 Jeff726
Jeff726
    4th Gear
  • PipPipPipPip
  • 534 posts
Posted 04 January 2005 - 02:23 PM
What about a 2000 LE? Do I have discs or drums? All I know is that pads go up front and shoes in the rear.
#6 tinto99
tinto99
    3rd Gear
  • PipPipPip
  • 338 posts
Posted 04 January 2005 - 02:35 PM
Sounds like front disc brakes to me.
If I recall correctly it's 'disc pads', and 'drum shoes'.
#7 fishexpo101
  • 10076 posts
Posted 04 January 2005 - 04:59 PM
Yup - tinto99 is correct.
Of the US bound 9th generation Corollas - only the XRS has front and rear disc brakes. All US 8th generation and non-XRS 9th generation Corollas are front disc and rear drums.
There are some "write-ups" on the net for doing a drum to disc conversion with different donor cars - but more are not 100% complete. Lots of people do the conversion but retain the OEM master cylinder. Normally, you'd want to swap for the master cylinder in the donor car or play around with the brake biasing - or you will get unpredictable results in emergency or heavy braking.
#8 dogdenii
dogdenii
    1st Gear
  • Members
  • Pip
  • 10 posts
Posted 05 January 2005 - 07:31 AM
The brake booster and master cylinder from a V6 toyota truck looks to handle the bill just fine. Same mounting and the V6 is a dual diaphram Booster w/1" bore master. Are the rear assemblies on the 8th, 9th gen the same? I think the toughest part would be the caliper mount and the caliper postions.
#9 fishexpo101
  • 10076 posts
Posted 05 January 2005 - 11:49 PM
As far as I know - the rear brakes are the same for 7th and 8th generations (1993-2002). The 9th generations (2003+) use a different hub assembly but could be made to fit with some work.
#10 dogdenii
dogdenii
    1st Gear
  • Members
  • Pip
  • 10 posts
Posted 06 January 2005 - 09:04 AM
Thanks for the information.
After I finish up the CB (still haven't figured out an asthetic place for the antenna) I'll be working on the rear disc brake swap.
#11 Dr Tweak
Dr Tweak
    1st Gear
  • Members
  • Pip
  • 14 posts
Posted 07 February 2005 - 12:54 AM
I'm working on one right now using Celica parts... we'll see how it works out.
#12 Guest_childdamien_*
Guest_childdamien_*
  • Guests
Posted 19 February 2005 - 08:26 PM
look about importing the entire rear end from the ae102 levin or treuno with the positives being, thats what should have been there....and you get the lsd, that should also be there...i kno a guy that can hook you up...pm me if your interested gonna be about $600 or so
#13 mdakatkr
mdakatkr
    Neutral
  • 2 posts
Posted 23 November 2016 - 10:15 PM
Does anyone have the write up for this? I have a 99 Rolla and I'm interested in doing this. What donor car would be easiest for bolt on?
