2005 Corolla Shakes At Idle?
21 replies to this topic
#1 Guest_Corollasroyce_*
  • Guests
Posted 07 December 2004 - 05:23 PM
Hey All: I am new to the board, i purchased a 2005 Corolla CE, Package C about 3 months ago, and i notice that once the car has reached normal operating temperatures it will shake at idle, its nothing major, just a minor little shake like its going stall then it picks back up, its only about 100 rpms differnce between the stalling point and the pickup point. I took the car in to have a alarm installed and the loaner car i got was a 2003 Corolla CE base. It was an automatic and mine is a 5 speed, and both the cars did this. I am wondering if its normal, cause its kinda annoying but both the cars ive driven have both done it...thanks guys appreciate your help.
#2 GarrettSocling
GarrettSocling
    3rd Gear
  • Members
  • PipPipPip
  • 339 posts
Posted 07 December 2004 - 06:07 PM
mine does that as well, it has been getting better...nearly 4000 miles on it and I hardly notice anymore...but from brand new to 2000 miles i noticed it a lot.
#3 Guest_Corollasroyce_*
  • Guests
Posted 07 December 2004 - 06:12 PM
Yeh as i am looking through this site i have noticed quite a few posts about it, thanks for your responce though, my mileage is sitting at 4,000 kms' which is about 2500 miles, so hopefuly it goes away, and like you ive noticed it right from the day i picked it up at 6km's . wierd how i didn't notice it on the test drive, but like you said that car had about 10,000 miles on it so maybe it does just fade away...thanks for your input though :)
#4 carbon
carbon
    Neutral
  • Members
  • 5 posts
Posted 22 January 2005 - 02:44 AM
If the defrost or AC are turned on the AC compressor will drop the RPMs of the motor during idle and the ECM will kick it back up to compensate... that could be causing thing the odd idle... thats what my 01 does...
#5 Guest_Corollasroyce_*
  • Guests
Posted 22 January 2005 - 03:06 AM
No its not that...it does it all the time, under all circumstances, its just a rough idle we've come to conclude...mine still does it....4500 miles or 7400 kms
#6 Cherry128
Cherry128
    4th Gear
  • Members
  • PipPipPipPip
  • 722 posts
Posted 22 January 2005 - 09:51 AM
The engine mounts have a resonance at a particular speed. under the right circumstances of air temperature and engine load from headlights or air conditioning, the idle would hit the resonsnce and cause the engine mounts ot transmit a strong vibration.
If it does it all the time, perhaps your dealer can adjust the idle speed. As little as 50-100 RPM will brign it above that resonance frequency.
#7 jims99
jims99
    1st Gear
  • Pip
  • 80 posts
Posted 22 January 2005 - 11:17 AM
Hey C - R, what idle speed are we talking about here? Perhaps the initial speed has been changed or drifted since purchase. As the others have said, any variation in idle speed will cause strange stuff.... have the mechanic set the idle up to specs for your model. Should be reasonable to do so... Good luck, Jim.
#8 Guest_Corollasroyce_*
  • Guests
Posted 22 January 2005 - 12:37 PM
Yeh im not the only one that experiences this, this is an old post.....were talking it drops to about 400 rpm...as you can imagine the engine idles VERY rough at this point and i have driven several 04-05 corollas and they ALL do it...
#9 Ti-Jean
Ti-Jean
    3rd Gear
  • Members
  • PipPipPip
  • 488 posts
Posted 22 January 2005 - 02:03 PM
My 05 is set up differently than your 01. When the AC compressor kicks in, idle speed goes up to 1200 rpm. Probably to avoid that vibrating under load idle.
My 99 Accord was vibrating slightly at idle when the AC compressor was on.
Royce,
Do you have a lot of power accessories on when you notice this vibration?
Things like fan speed at max, all the lights and rear defrost take up of a lot of what your poor battery and alternator can produce. Especially in very cold temps and short trips.
If not, I would have it checked at the dealer
For one, I have never seen my idle go so low, but I never use my rear defrost and always wait til I start rolling to turn on the lights and fan speed.
Funny, because both our cars may have been built on the same day or week...
Edited by Ti-Jean, 22 January 2005 - 02:10 PM.
#10 Guest_Corollasroyce_*
  • Guests
Posted 22 January 2005 - 02:13 PM
Naw Jean, almost nothing on, if anything just the defrost at low.....
its not just sence it started to get cold, this is an old post, carbon revived for us...heh....anyway, its not just my car, garretsoclin has the same problem as do a few others who i can't recall right now, and i got a 04 to test drive while they installed my alarm, it was automatic and it did the exact same thing....thats wierd that your car hasnt' done it, youve never noticed a low idle vibration? as soon as i move the sterring wheel or something it goes back up, if i touch the brakes, but once the car is fully warm and i pull up to light or stop sign it idles hard like its going to stall, its been brought up a few times in this forum but noone knows why, we came to conclusion its just the way the car is....like the stupid 4th and 5th gear...the ratios are so damn close on the highway you have to sift to 3rd to get any power...just another annoying thing about the car.... :P
#11 Ti-Jean
Ti-Jean
    3rd Gear
  • Members
  • PipPipPip
  • 488 posts
Posted 22 January 2005 - 02:33 PM
It drops for how long? For example when you stop at a light?
You're right for the bad gearing between 4th and 5th.
Here are the gear ratios for the 5 sp Corolla/Matrix with the 1ZZ-FE;
1- 3.166
2- 1.904
3- 1.310
4- 0.885
5- 0.725
Diff. 3.941
Look how close 4th and 5th are. Only 500 rpm between the 2.
It's ok for city or the "plains", but not so for hills or passing.
I would have put 4th around 0.93.
#12 Guest_Corollasroyce_*
  • Guests
Posted 22 January 2005 - 02:39 PM
Yeh i agree.....4th is wayyy to close for passing on hills, you have to goto third....stupid why their so close together....=p
the rpms drop untill i give further input, ie turn the sterring wheel, or press on brake pedal....otherwise if i am just sitting there in neutral with clutch pressed...it will drop to 400 rpms till i start moving again....if i stop at a light it will do it the whole time.....so i figured it was something to do with it being 5 speed, but when i got my loaner car it was 04 CE automatic and it did the exact same thing....
#13 Lethal 7
Lethal 7
    2nd Gear
  • Members
  • PipPip
  • 199 posts
Posted 22 January 2005 - 04:04 PM
Wierd, my 2003 CE 5spd idles at 750RPM when warmed up. Doesn't go up or down.No bad vibrations nor does it feel like stalling. Nothing. No defrost, in neutral. Turn the steering wheel and it raises slightly. A/C on and it goes up for 1,100 for a sec, then down to 750RPM again for some seconds, then a rise to 1,100.
The gearing blows to much of a gap between 3-4 and the 4-5 is too close, I am usually used to 4th being 1:1 or pretty close. Ah well. The 1ZZ-FE Celica GT ratios are pretty decent.
#14 Ti-Jean
Ti-Jean
    3rd Gear
  • Members
  • PipPipPip
  • 488 posts
Posted 22 January 2005 - 04:23 PM
Definitely never seen idle speed drop so low on mine.
#15 Max
Max
    5th Gear
  • PipPipPipPipPip
  • 1587 posts
Posted 22 January 2005 - 06:06 PM
Lethal7, my car acts exactly as yours does. It's quiet, doesn't idle strangely, and does not vibrate or threaten to stall.
