How long does a Toyota last?
7 replies to this topic
#1 Guest_nicagrace_*
Guest_nicagrace_*
  • Guests
Posted 06 April 2004 - 07:23 PM
Hello everyone! I need some help in figuring out how long a Toyota will last. I am looking into buying used Corollas from the 80s that have from between 120,000 to 156,000 miles on them. Does anyone know the upper amount of miles a Toyota can have before it gives out? I don't want to buy a car with that many miles only to have it die a year later. Thanks for your help!
#2 c2105026
c2105026
    5th Gear
  • PipPipPipPipPip
  • 1,095 posts
Posted 06 April 2004 - 07:29 PM
all depends on service history and the quality of replacement parts used. If genuine toyota parts/ premium brand are used it those corollas will have plenty of life left in them . Depnds on what work has been done etc. at 156,000 miles you may get 3 yrs out of it, depending on the meileage you do.
#3 fishexpo101
  • 10,055 posts
Posted 07 April 2004 - 10:05 AM
C2105026 is correct - you can have lots of miles on the car and still get years of use, as long as it has been taken care of properly. Ask for service records if they are available, have it checked out by a qualified mechanic for signs of damage - either previous abuse or impending failure, and it wouldn't hurt to run it through a service like CarFax or similar. Good to know how many owners the car has had - may give you an idea of the kind of lifespan it will have. If it had a single owner, you may be able to get a car history from them - if it has traded hands dozens of times before, may be a problem car that is just being dumped off to someone else.
Good Luck.
#4 Guest_lassendavey_*
Guest_lassendavey_*
  • Guests
Posted 12 April 2004 - 06:34 PM
With over 400,000 miles on an '86 Camry whose engine was rebuilt at 243K for preventive maintenance, and 5 speed tranny rebuilt at 275K when a needle bearing went out, I suspect that a well taken care of Toyota anything (well, almost anything), should have a great many more mile on it.
My car was purchased new, had very little maintenance over the years other than minor wear and tear, and had the oil & filter changed every 4K, with OEM filters and Castrol GTX.
I would gladly buy a vehicle as described, if service records are known and honest info about the car is provided.
Dave
#5 Guest_FrankS42_*
Guest_FrankS42_*
  • Guests
Posted 13 April 2004 - 12:35 AM
Don't know where you are from but beware of rust problems for pre early 80 models, here in New Zealand panels were imported from Japan for assembly here and there was a lot of problems with rusting during the sea voyage from Japan. The other problem is beware of any tyres that are over about 15 years old, had a case here of a tyre built 86, still plenty of tread left, passed local Warrant of Fitness but blew on the Motorway killing the driver.
#6 Guest_sphs_*
Guest_sphs_*
  • Guests
Posted 21 April 2004 - 02:03 PM
How much throttle do you usually drive with? How often do you redline?
#7 Slalom44
Slalom44
    3rd Gear
  • Members
  • PipPipPip
  • 306 posts
Posted 25 April 2004 - 09:48 AM
I agree with the above posts. Keep in mind that miles are not the only measure of wear on a car. If the CV boots are original, it is possible that they may start cracking, causing CV joint failure. Brake caliper seals can also dry out over time, regardless of miles. My point is that anything made of rubber on your car can deteriorate over time, especially if exposed to sun & the elements.
You may want to do a compression test on the engine. That's a good indicator of how well the engine (and thus, probably the rest of the car) was maintained. If you don't want to go through the hassle, at least have someone start the car while you stand behind it. Look at the exhaust pipe. If blue smoke comes out or if the initial exhaust gases smell like oil, then the rings are probably worn. Don't worry about white smoke - that's just water vapor from the combustion.
Another thing: make sure that the timing belt has been replaced. If not, then you'll need to do that immediately which will cost you a few bucks. I believe that those old Corollas had interference engines, meaning that you'll bend the valves if you break the timing belt.
#8 Ghost
Ghost
    3rd Gear
  • PipPipPip
  • 471 posts
Posted 27 April 2004 - 10:34 AM
Also regrounding the engine may help its performance. An '80s model would have corroded ground points, if original.
(I know this in no way answers the question "How long does a Toyota last?")
